AR breakdown Clarification
My allroad has been in the shop for 3 months total. It was driven for only one week in out of those 3 months. Last night it had trouble starting and after 10 mins of rest the car started and drove. My allroad lost all engine power but still had electrical power No CEL warning (Check Engine Light). Had to call ARSA(road-side assistance). When I was waiting for a tow I tried to start the car about 50 times. It would turn over but the car wouldn't start. I could smell the electrical burning smell. The Volt meter shows 14V and the battery is about 1 year old. When it got the repair shop which is closed on saturdays it started up. It seems that the vehicle only wants to go 5 miles at a time and then it needs a rest. What do you guys think it is? Any experiance with this? any diagnosis or suggestions would help me help the dealer fix the car. Thanks in advance you guys have always been supportive... The car has 61K miles and has not been driven for the last 2-3 months.
maybe water/sludge settling to the bottom of the tank while sitting.....
then working it's way through the system causing erratic starting and running. If that's the case hopefully it will just work itself out or you might just need a new fuel filter.
Please clarify....
Lost all engine power:
1. Running then died?
2. No power to turn the starter motor?
If it was 2 its possible that yo have a loose battery terminal or cable. If its 1.. then a VAG scan will likely tell the tale.
You are correct
The car was running and then sudden loss of power. The night before I had turned off the car for 10 mins and then tried to start it. I tried for 10 mins then it started up again. Thanks
I had a similar problem with a MB--was the electric fuel pump solenoid.
Two things (simplified) required to start assuming engine turns over:
1. fuel
2. spark
Remove spark plug and hold it against the block (with wire attached) and see if it sparks. With nothing in the spark plug hole sniff for fuel. The problem I had was similar but in a 1981 Mercedes Benz 230 I had in Germany when I was in the military. Easy to test on an old style 4 cylinder engine. Don't know if you can do it on our allroads.
Since the solenoid was intermittant, everytime I towed it to the dealer it started right up. They said, sorry but they can't fix the problem until it happens to them. I left the car with them for a few days and twice a day they would try to start it until one day it didn't and they found the problem.
Hope this helps.
1. fuel
2. spark
Hope this helps.
Refs
12-18-2013 02:44 PM
FirstQuattro
04-20-2009 08:31 AM
TwisTTer
27
05-05-2008 08:11 PM
corne
Audi 100 / A6 (C4 Platform)
12-03-2007 07:17 AM
