Arnott Inc ar airspring
Old 10-03-2008, 06:14 AM
New Member
StevenM's Avatar
Default Arnott Inc ar airspring
Well, I have one on order, arrives today. Will post next week once installed and on the road.
Old 10-03-2008, 06:27 AM
TwinTurboTerror's Avatar
Excellent.
Old 10-03-2008, 08:04 AM
ar-Rings's Avatar
Default I would favor replacing both in front or rear, unless OE. Why? I don't know, maybe
because of the aftermarket thing. YES, please keep us all posted and several pics (side by side,etc). Front or rear?
Old 10-03-2008, 08:22 AM
allestraße's Avatar
I had the same thought. Maybe they are identical to OE, but who knows?
Old 10-03-2008, 08:43 AM
New Member
StevenM's Avatar
Default Re: Arnott Inc ar airspring
Someone has to dip their toe in the water, I guess it is my turn. I replaced a OE a few months ago. The cost difference is appealing. Will hope thier compatable in preformance. They claim no need to replace them in pairs. Let you know.
Old 10-03-2008, 11:30 AM
paulroad's Avatar
Default consider this....
if it was a steel spring then the load and rating would need to be the same fomr MFG to MFG.
But.. being its doing nothing more than holding air according to the pressure sensors of the suspension system then there is no true difference. Assuming the dimensions are all the same. With our system the ride and rebound is more about the shock than the air spring.
Old 10-03-2008, 02:18 PM
ar-Rings's Avatar
Default I just remembered - Fronts only at this time ...
Where are you? I am in need of some dimensions on the front six hole bolting pattern for some CAD models I would like to finish for coilover spacers. I really do not feel comfortable with them without a visual inspection of some plots I've made.
Old 10-03-2008, 02:31 PM
New Member
StevenM's Avatar
Default Re: I just remembered - Fronts only at this time ...
Atlanta. Part was shipped directly to the indy.
Old 10-05-2008, 01:12 AM
kingfishgrapejam's Avatar
2nd. just do one at a time. The other side will fail soon enough.
Old 10-05-2008, 08:38 AM
Member
viny's Avatar
Default So what's the concensus?If one in front leaks change that or both front?
I'm at that poin: the front end usually looses a level overnight.........The dealer can't find a leak, so I guess I will end up replacing both fronts?
Quick Reply: Arnott Inc ar airspring
