Car shift points are off, loss of power, revs above 2500 result in near stall.
Old 05-30-2006, 08:57 PM
New Member
laybournallroad's Avatar
Default Car shift points are off, loss of power, revs above 2500 result in near stall.
Possible that APR upgrade is the culprit. I don't wanna call them if it's not but since just got new APR upgrade last week, seems to be an issue. Thoughts before I call Hartmann?
Thanks,
Chris
Old 05-31-2006, 02:44 AM
paulroad's Avatar
Default sounds like safe mode could be engaging...
or the turbos are shutting down. The feel must be very different with the TIP vs. a manual.
It can be as simple as a hose leak or software. In any case I'd get right to your installer and check it out ASAP.
Old 05-31-2006, 03:30 AM
xtreetoes's Avatar
Default If you want to do initial diagnosis get a vagcom and pull
codes.
Old 05-31-2006, 07:52 AM
blackIIIroad's Avatar
Default Mass Air Flow Sensor (MAF)
If possible, try stock program to see if it goes away!
Old 05-31-2006, 08:00 AM
audilocks's Avatar
Default Same here with GIAC - post below - limp mode sucks,
especially going 90 uphill toward Lake Tahoe on Int 80. Can't pull over fast enough to avoid getting hit from behind. VAG will help id the codes and clear them and the CEL. I'm working with my installer to remedy the problem, will post when I know more. Check with Ex Pkw, he may have some clues.
ChrisEVO
Audi A3 / S3 / RS 3
02-07-2008 01:22 PM
Scott Long
11-10-2007 10:46 AM
docmusolf
04-11-2004 07:31 PM
M3KILR
9
09-30-2003 06:19 PM
Quick Reply: Car shift points are off, loss of power, revs above 2500 result in near stall.
