Codes, codes, codes. Any help divining the truth?
Thanks!
Address 01: Engine
Part No: 4Z7 907 551 M
Component: 2.7l V6/5VT G 0001
Coding: 06752
Shop #: WSC 20205
WAUYP64BX1N082270 AUZ7Z0Y1646076
6 Faults Found:
17867 - Exhaust Gas Temp Sensor 2 (G236): Implausible Signal
P1459 - 35-10 - - - Intermittent
17862 - Exhaust Gas Temp Sensor 1 (G235): Short to Ground
P1454 - 35-00 - -
17539 - Oxygen (Lambda) Sensor; B2 S1: Internal Resistance too High
P1131 - 35-10 - - - Intermittent
17831 - Secondary Air Injection System; Bank 1: Insufficient Flow
P1423 - 35-00 - -
17819 - Secondary Air Injection System; Bank 2: Insufficient Flow
P1411 - 35-00 - -
17870 - Exhaust Gas Temp Regulation for Bank 2: Implausible Signal
P1462 - 35-10 - - - Intermittent
Readiness: 0000 0000
I'm not sure if my entire system is working, so it may be worth a shot to see if it works in yours.
I could do this this weekend, sunday, if interested?
Also, it sounds like your EGT sensors are dying - easy fix.
