Codes Galore
My CIL popped the other day coming home from work. I had bought the car in Jersey, and drove it all the way home to CT with no problems, except for the bouncing shocks from a failing compressor. The car ran beautiful, with maybe a slight hesitation when accelerating. Probably the turbo lag that I'm not used to yet. Here's what I pulled:
Address 01: Engine Labels: 078-907-551-AZA.lbl Part No: 4Z7 907 551 A Component: 2.7l V6/5VT G 0001 Coding: 06752 Shop #: WSC 02335 VCID: 4189557B4BCED82921E-5140 WAUYP64B61N****** AUZ7Z0Y1497962 8 Faults Found: 17861 - Exhaust Gas Temp Sensor 1 (G235) P1453 - 35-00 - Open or Short to Plus 17867 - Exhaust Gas Temp Sensor 2 (G236) P1459 - 35-10 - Implausible Signal - Intermittent 17870 - Exhaust Gas Temp Regulation for Bank 2 P1462 - 35-10 - Implausible Signal - Intermittent 17869 - Exhaust Gas Temp Regulation for Bank 1 P1461 - 35-10 - Implausible Signal - Intermittent 17887 - Brake Boost Vacuum System P1479 - 35-10 - Mechanical Failure - Intermittent 17539 - Oxygen (Lambda) Sensor; B2 S1 P1131 - 35-10 - Internal Resistance too High - Intermittent 17831 - Secondary Air Injection System; Bank 1 P1423 - 35-00 - Insufficient Flow 17819 - Secondary Air Injection System; Bank 2 P1411 - 35-00 - Insufficient Flow Readiness: 0000 1000 Address 06: Seat Mem. Pass Labels: None Part No: 4B0 959 760 C Component: Sitzmemory R1 BF 0101 Coding: 00001 Shop #: WSC 00000 VCID: 2D5119CBE7562C49F56-4B00 1 Fault Found: 01729 - Switch for Seat Height Rear Pass. Seat (E66); Down 28-10 - Short to Plus - Intermittent Address 15: Airbags Labels: 4B0-959-655-AI8.lbl Part No: 4Z7 959 655 C Component: Airbag Front+Kopf 1000 Coding: 00307 Shop #: WSC 02335 VCID: 4FAD63438D9A3E59A7A-519A 1 Fault Found: 00588 - Airbag Igniter; Driver Side (N95) 64-10 - Not Currently Testable - Intermittent Address 34: Level Control Labels: VCID: 55A1912BAC4644896D6-5124 Note: Excessive Comm Errors Address 35: Centr. Locks Labels: 4B0-962-258.lbl Part No: 4B0 962 258 J Component: Central Lock/Alarm D33 Coding: 15885 Shop #: WSC 02335 VCID: 306F00BFF06441A1DE0-4ECE 3 Faults Found: 01572 - Alarm triggered by Door Contact Switch; Passenger Side 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 00955 - Key 1 09-10 - Adaptation Limit Surpassed - Intermittent Address 76: Park Assist Labels: 8Z0-919-283.lbl Part No: 8Z0 919 283 Component: Parkingsyst. A6 RDW D02 Coding: 01186 Shop #: WSC 02335 VCID: 020B9A770E480331784-5140 1 Fault Found: 01317 - Control Module in Instrument Cluster (J285) 49-10 - No Communications - Intermittent I haven't driven the car since I cleared them all, because the front end is just about scraping the ground. I know I need to check all of the fuses first, and try re-soldering the EGT. But with all of the other electrical issues, is there maybe a master ground issue? The battery had been replaced as well, so that may explain some issues. |
A lot of those codes could have been set a long time ago. Only a few will trigger a CEL
Now that you've cleared them, drive it, and see if any recur over the next few days. Chase those down, and fix things. A run down battery some time in the past can cause a lot of error codes. So many of what you have are intermittent, so clearing and rechecking later is the best option. |
That's what I figured. It wasn't a good sign that the dealer had a jumper box in the back seat when I picked it up. Once it gets above 4 degrees out, I'll rebuild the compressor, and take it for a spin.
