Coil Conversion Install
#11
I'm sure you can crank it up higher, the question is, how much higher up the coil you have to go from the middle of it.
If it's 1 inch, there should be no problem. If it's 2 inches, then I wonder what effect it will have on longevity and handling, as that is probably out of spec.
#12
#14
Great questions and I wonder the same things. I've never seen a coilover kit that didn't let you put it at stock height or higher, but this'll be my first Audi experience, so I'll be curious to get my hands on it. I am a little baffled at H&R's lack of technical documentation online ... ?
I swear, we spent no fewer than 5-6 attempts of me paraphrasing the question and her response being the same.
This time around, she couldn't answer my question, and promptly put me to another tech.
#15
H&R has strange people on the phone. I called them once before several years ago, and the first person to pick up the phone (a receptionist) did not answer my question, kept repeating the same answer, and refused to connect me with someone more technical knowledge.
I poked around the Internets with the part #'s of my set (F46-1001-1/1; R46-1011-1/1) and couldn't find anything but German catalogs. No technical info whatsoever.
Maybe I'll try calling as well. That is so strange.
#16
Any more progress on this?? I have Gen II's with Bilsteins, but I am pretty fed up with the quirks of the whole system as far as how horribly it drives in level I and trying to get all of the corners a the cporrect height through the 402 adaptation process. I am really seriously considering swapping out for coilovers or the Arnott or Blau Parts setups, but it would be perfect if you could get these at something close to level 1-1.5 rather than level II. Any ideas? I wonder if they would consider making a few sets of these with slightly lower springs in them???
#17
So I have the H&Rs on the allroad now. Measuring from the bottom of the shock threads, distances to the bottom of the locking ring of 2" in the back and 2.5" in the front results in 25" rear and 24" front ground to fender heights.
They went on SUPER easily, my only advice is to set the rear height BEFORE installing them since they are next to impossible to adjust once installed. However the fronts are very easy to adjust in-car.
These H&Rs are FANTASTIC on the road. It is very much a street setup, and isn't too stiff which is good considering the lack of damping adjustment.
I would recommend these coilovers to any allroad driver sick of dealing with air ride issues.
#19
Congrats!
#20
Installed with heaps of anti-seize:
Here's how I have it set, forgive the snow tires and stock rims at the moment!
