Cooling fan problems
I have a 2002 Allroad that I am having problems with the cooling fans not shutting off. I have since removed the fans and am still trying to diagnose the problem. I have found both coolant temperature sensors and tried bridging the connectors in the plug. With no avail the fans will keep running. I also do not have any cold air conditioning. I also would like some input on what are the best set of electronic fans to mount when I start to button everything back up. If I get that far
J293
This is essentially a module J239 sitting in the engine compartment front left side. But first check to see if the thermal switch causes malfunction. Just unplug it for testing (Located in the bottom part of the radiator on the left side)
mgcman
Audi 100 / A6 (C4 Platform)
06-22-2006 06:17 AM
