Does this look healthy? Non modded 60K mile Boost logs. Milpitas?
I am attempting to baseline my car before modding. I have almost 60K miles on it at this point and even have original BPVs in place.
With that said, does this requested vs. actual boost graph look right?
<img src="http://mywebpages.comcast.net/ryanjen1/allroad/VAG-COM/3rdgearpull.jpg">
Yep quite healthy, no issues there.. Charting lesson. RPMS on bottom
Boost on left and if need be a second axis on the right (timing etc). time means nothing unless your looking for a baseline 60-100 time
Is this better? I put the timing on from the same pull, but the timestamp didn't match on
the second measuring block. I guess that's why the timing line looks like it has been shifted left.
Either way, I guess the jist is that my car is making expected boost after all these miles. That is a good thing. What is max boost in a stock allroad supposed to be?
<img src="http://mywebpages.comcast.net/ryanjen1/allroad/VAG-COM/tryagainplot.jpg">
It is reading 1600 mbar which is equal to 1.6bar...
this is the way it comes out of the VAG-COM. Ambient atmospheric pressure at sea level (I'm pretty much as sea level in Annapolis) is 1.0 bar.
So, I guess my car is making .6 bar or about 8.7psi of actual boost pressure.
Does this sound right?
I just dug around a bit in the S4 forum and see that a stock 2.7T should make
perhaps a little more than my car does. Some people said it should do up to .68 bar or almost 10psi but I did not see any real plots with those figures.
Most stock 2.7T plots that I found were doing around .60 to .62 bar of actual boost. This is in the 9psi range.
I have some 710Ns. Upon installation hopefully they will snap shut better
and my boost will build quicker. This is one of the reasons why I want to baseline my car. I want to see evidence of mods improving performance.
petervan
10-16-2006 03:48 PM
Desired AFR Part II: Logged With Road Course Boost, Graphs Inside Comparing To Street Boost Curve...
PSmalls::AnalRetentiveNumbNut
76
09-13-2006 08:34 AM
Oo.et.oO
10-14-2005 11:21 AM
Matt Devo
VAG-COM Discussion
04-08-2005 08:51 AM
