Front Suspension Noise
I have a 2004 Allroad that has been pretty lovingly cared for by 3 users total over the years. It has a few aftermarket components, such as a chipped ECU and a Hotchkis suspension kit. About a month ago, there was a strange noise coming from the front suspension, particularly at slow speeds. However, it subsided the same day it started, and has not occurred since in a month of consistent driving including a road trip from NYC to Boston and back. However, yesterday it began again, was much more consistent, and louder.
I would describe it as a "moaning" noise in the front half of the car that only happens at slow speeds (< 20 mph) and is directly linked to the rotation speed of the tires (you can hear it speed up/slow down in the recordings below). It almost sounds like it's coming out from inside the dash, but I'm pretty sure it's something in the suspension/drive train. It can be felt as well in the gas pedal when it occurs, as a vibration. Either applying more aggressive acceleration OR applying the brakes both cause the noise to stop. It essentially only occurs at low RPMS (< 2500), without any braking, under 20mph. Here are some links to the noise that I recorded yesterday: https://mega.co.nz/#!2Q01kIAR!NgG9Rg...63rRNBIHP27JmA https://mega.co.nz/#!2E0nmaZI!BDB9-S...qhararVE-2j5v8 My biggest concern is that it's a quick fix now, but could be doing serious damage to the vehicle. Would love to hear any thoughts! |
Brake shield rubbing?
Originally Posted by GTA_Driver
(Post 24467898)
You've got to remove the wheel and see what's going on there and where rubbing occurs.
Can you please post some pictures so that we can know what is the main problem in your car
Originally Posted by CharlesECalloway
(Post 24468166)
(Post 24467898)
next thing i would check would be the cv axles |
Originally Posted by PaperToast
(Post 24468974)
easiest to check first
next thing i would check would be the cv axles Thanks! |
Sounds like it could be a control arm. Sometimes the rubber bushings dry out and start to make creaking/groaning noises.
It's not uncommon for control arms to need replacement over the years. Jason |
Can't play your audio message.
If the sound is rotational and varies with speed, it has to be some of the rolling parts like the brake caliper not retracting the pads, the CV joint exposed and contaminated from a torn boot, the wheel bearing failing, etc. |
