GRRRR!!!! D@mned dealer just called, they can *not* align the car in level 1. WTF?!
Their alignment rack is plugged into the stupid vehicle computer and won't give readings unless the ar is parked at level 2. Thus, they have no way with their machine to align it on level one -- where I always keep it.
I guess one could 402 the car down a whole level before taking it in for alignment, then put it back up after. Has anybody figured out another solution?
I have a whole bucket full o' curses for the Audi fools who are making systems so integrated and user-lockout-based that they hinder ownership more than help it.
Camber and toe change. Camber goes -1/4 for each level change, and toe
goes toe in in the rear as you lower. I played with the camber readings on my car as I 402'd a couple of years ago. In the front, if you 402 to lower the car by 12mm in the front, you end up with -1.75 degrees in the front. Can't be adjusted so you need to rotate frequently. Same thing in the rear, but you can adjust the rear.
I just took my car to a good indie alignment tech and had it done on L1. Only thing he couldn't do was VAG the steering input after adjusting front toe, but I did it myself so no big deal.
Evil Buddha
RS4 (B7 Platform) Discussion
08-07-2007 12:37 PM
KaMaKaZieP -ALUMIN8-
11-21-2004 12:16 PM
velo
06-18-2001 04:40 PM
