Help! 2001 Allroad Ignition problem
So today when I went to start my car the ignition seemed to be locked, like when you just need to jiggle the steering wheel to turn the key. I jiggled the steering wheel and there was still some resistance, but I tried to turn the key anyway and I think I broke something inside the ignition? Is this even possible?I heard a snapping noise and the key will turn to starting postilion, all electrical items, radio, windows, dash lights, etc work but the car makes no attempt to start. What did I break? I haven't even owned this car 2 months. . . . :(
It sounds like the lock tumbler may be broken. If so, the ignition key switch will need to be replaced.
Originally Posted by snagitseven
(Post 24713824)
Originally Posted by lysmix
(Post 24713938)
How do I go about checking to see if that is the issue, and more importantly how do I keep it from happening again once I replace it?
(Post 24713938)
(Post 24714114)
Got the repair manual out, first step is to remove the airbag. Beyond our capabilities, to the import mechanic it goes. :(
Should be a pretty easy repair once you get to the part. I wouldn't think you need to remove the air bag.
these are the parts you would need https://www.carpartsdiscount.com/cat...ml?3593=512960 https://www.carpartsdiscount.com/cat...ml?3593=137729 use this code (4FVL7K) at checkout to received 10% off your order for being a forum member! |
