HELP! Installing hp-2 brakes, missing the ribbed washer for the bolt to the hub plate.
Old 04-29-2007, 08:16 AM
grey-2002-ar-6sp's Avatar
Default HELP! Installing hp-2 brakes, missing the ribbed washer for the bolt to the hub plate.
The old calipers don't use a ribbed washer.
Is this a MUST?
I'm in the middle of the job now - if the washers are a must, I can get my regular indy to put them in tomorrow when I get the car inspected.
Old 04-29-2007, 10:37 AM
skidmark's Avatar
I don't recall any washers.
Old 04-29-2007, 10:39 AM
Default I went back and searched the archives; couldn't find any mention of them there either.
The passenger side caliper has been swapped. I'm about half-way through the other side. Once that's done, I'll bleed the front.
Old 04-29-2007, 01:16 PM
Default Update: Brakes are installed. I'll have my shop check a few things when I'm there tomorrow...
. torque on the caliper bolts
. passenger side abs sensor connector didn't want to seat in the bracket
. I couldn't find the last turkey baster I defiled, and didn't want to tell my wife to buy yet another new one, so the shop can adjust the fluid level in the plastic tank with their baster
. bleed the brake system again - seems a little mushy, and doing the vag-com cycle is a lot easier with two people, which I didn't have today.
syndicate_77
9
03-18-2014 03:00 PM
JasonS4+Festicle
05-16-2006 12:18 PM
heretic
11-30-2005 03:34 AM
egp320i
10-16-2003 01:35 AM
randy@5280
07-08-2002 09:41 AM
Quick Reply: HELP! Installing hp-2 brakes, missing the ribbed washer for the bolt to the hub plate.
