HELP !!! URGENT !! PLEASE !!!!
The transmission swap is done, well, almost.
The darn AT ECU doesn't take any programs that KMD tried out (checksum difference?).
Where can I find a used MT ECU for the ABP (must match) Engine code? 4Z7 907 551 or 551M or 551X.
Any kind of help or pointers into the right direction would be very much appreciated !!!
a thought......
Perhaps if you flash your Dahlback coded actual chip back to true OEM stock this will allow the other programs to work. (a hard reboot)
Then you should be able to reflash with the perofmance program.
Danny tried multiple things, the problem seems to be the different checksum between an MT and AT, if
this doesn't match then the car wont recognize the code no matter what code is in the ECU.
So after handing over 2 AT ECU's to play around with, we are out of fuel here....it must be a MT ECU for this particular engine code.
The ECU for the MT and AT are quite different in terms of
operation... I cant believe you didn't ask about this first!!! :-) IIRC the boxes are physically different (internally) which likely would cause problems.
Just get the MT ECU and you should be good.
Believe me, I've asked more questions then you could shake a stick...
and just getting a MT is what I'm trying to do here, but a used one would be nice considering the price of a new ECU.
A broken one would do the trick too because it could be repaired by ECU direct.
Why do you think I provided my second ECU to figure all this out, it's a pain in the Glutus Maximus but I can wait another month ;-)
I'll buy your TIP ECU if it is for sale!!!
You won't need it (er.. either of them)....
Please
Sorry, I have no clue where to get one.
Where did you get two Tip ECUs?
Good luck finding one, please post where you got it when you do....
Please
Can they use ecufix? It should work with the equip they have. Point them here...
<ul><li><a href="http://andywhittaker.com/Home/ECUFix/tabid/53/Default.aspx">http://andywhittaker.com/Home/ECUFix/tabid/53/Default.aspx</a</li></ul>
No problem, if this works out then I'll surely put them up for sale.
One was destroyed hitting an hole in the road, it was fixed after I had to buy a new one (soldering socket came lose.....Bummer ;-)
