Level Control
Does anybody where the Adaptions for the auto-level Speeds are located ??? I want to do some Dune driving, but I need speed and height to climb these buggers when I reach a 100km/h the Car sits down to Level 2, need at least Level 3 !!
How about the reverse 402?
You could raise the car with the 402 mod so that level 2 is higher than stock.
I don't think there is a way to shut off the speed based lowering, except maybe on the first year or so where they had a manual mode. |
Re: How about the reverse 402?
Don't want to shut it off, but surely somewhere in the Adaptations the Speed is programmed, and surely this can be changed, the Question is just where ????
Speed changes are located in the controller firmware. As mentioned use the reverse 402 mod in this
case 382.
even the manual mode lowers at @ 80mph...bottoming out in a gravel wash at over 100mph, ftl.
You saying your 01 goes to level 1 in manual mode @ 80 mph? Mine stays in level 2 to well over 100.
Not tested on mine quite to 100, but well over 80...I keep mine in manual to avoid the
up/down in traffic and it seems to avoid the vibration I was having at higher speeds. You must not have an '01...from what I've seem manual is manual for level 2, except for the higher levels that do have "safety" releases for higher mph.
