Pilot Sport A/S Owners - What's your PSI?
I'm runnin' about the same as itacud. 245/50s.
have some concern about wearing out the middles, but with heavy car I need all the stiffness I can get for "hussling" as itacud puts it.
interesting, front pressures are higher than rears?......
This is my first experience with AWD. With RWD, my rears are always higher pressure than the fronts. Is the reason your fronts higher than the rears due to the AWD?
BTW, I took out the SL for the first time in a while, and going around an offramp, I was like "whoa, that rear feels loose!" AWD definitely has tremendous dry performance/security benefits.
It's really because of the weight over the front wheels...
YZF996... originally suggested that I try the high pressure up front. Track testing confirmed, roll over of the front tires diddn't reduce to acceptable levels (under hard cornering) untill the cold tire pressure was up quite high.
I'm a little worried about running that pressure for commuting, however, as it seems to be wearing away the centers. I think I'll drop pressures a little - but it will understeer more
do you have the psk bar?....
because I'm a bit suprised that the car doesn't have balance problems with higher pressure in the front. Then again, with awd, I suppose that makes up for any difference.
Yeah... have the PSK rear stabilizer. What do you mean by balance problems?
Are you wondering about differing outside tire diameters due to pressure differences? Hmmm... not sure if the weight up front eliminates that problem?
But, now I'm wondering if it might not be good for the torsen diff to have appreciably different pressures for normal commute duty?
what I mean by balance problems is the oversteer/understeer potential...
of having higher front lower rear air pressures vs. the traditional lower front higher rear air pressures. With RWD, normally the rear air is higher. With FWD I think it's higher front pressures to counteract the terminal understeer. But with AWD you're running higher front lower rears. I think the Audi AWD system sends the majority of the power to the rear wheels, so I assumed that the rear air pressures would be higher. but you're saying it works better the other way around? confused...
Actually, the Torsen normally biases front rear torque 50/50, unless one end experiances less...
....traction than the other.
That said, it's really the weight distribution that makes the car terminally understeer. The front wheels get overloaded first and they give up. This is made much worse, by the tires rolling over. So, the high front tire pressure just helps to deal with this weight, and to keep the tires on the optimal portion of the rubber.
2heretic
Motorsport Discussion
05-21-2003 07:15 AM
Al Cantara
Audi allroad
05-22-2002 08:04 PM
