Pulling the flasher-blinker switch/relay.
OK..I know its not rocket science. I pulled off the trim overlay and the switch/relay is in there VERY TIGHT. Naturally I don't want to damage anything.
Any suggestions?
Any suggestions?
IF, tabs exist on the sides. Maybe with the cupholder out you could depress the (edit)
tab on the right side. MAYBE into the backside with the stereo out.
Ok,,, obviously I've yet to do this on this car. Just ideas.
P/N 4B0 941 509C B98
Looks like tabs do exist on each side.
I used a putty knife to apply prying pressure while wiggling/pulling with needle-nose pliers.
I still did some minor damage to the relay case, but nothing serious.
On the new one, I spanked the side tabs so that it wouldn't be so hard to remove next time.
I used this post from the B5 S4 forum
Ended up pulling both the cupholder and the ESP/foglight in order to get a screwdriver in to push the hazard relay to one side, then pull out with opposite side hand. make sense?<ul><li><a href="https://forums.audiworld.com/s4/msgs/1783172.phtml">https://forums.audiworld.com/s4/msgs/1783172.phtml</a</li></ul>
JMBlur
04-01-2008 02:05 PM
Kingttr
06-24-2006 07:35 PM
art2.7t
11-10-2004 03:07 PM
