Q: Is there a performance rear disk that uses the stock calibers? Thx.
maybe the ones from the 4.2, but not the 2.7
the difference is in the thickness of the rotor. stock 2.7T rear rotor is a solid disk only 10mm thick. the S4 rear setup I just put on is a vented rear disc 20mm wide. IIRC, the 4.2 uses a vented rear disc also ~20mm wide.
wont these work?
<ul><li><a href="http://ecstuning.com/stage/edpd/pagebuild_v2.cgi?make=Audi&engine=2.7T&mod el=All%20Road&submodel=&category=Braking"> ecs tuning, look under the rear section</a></li></ul>
quattromano
06-05-2003 12:20 PM
Alf Arkin
06-18-2001 11:05 AM
