Go Back  AudiWorld Forums > Audi Models > Audi allroad
Reload this Page >
Removing Headlight Switch from Dash
Old 01-19-2010, 05:24 PM
  #11
The only thing is that the second hand one might last a few months or longer if you get lucky. The best thing is to find a good website that sells it cheaper I was wandering how much K2audi spent for it?! (thanks
indoor is offline
Old 02-15-2010, 11:11 AM
  #12
Default A4 - LED on headlamp switch flickering
Is the flickering indicative of an issue with the headlamps themselves, or is this just an interior lighting issue? Basically trying to figure out if replacing is critical. thanks.
Jay_Keating is offline
Old 02-15-2010, 01:03 PM
  #13
Benzie's Avatar
My flickering is just on the headlight switch. The headlights themselves are fine. I decided to leave the problem alone since it is so minor.
Benzie is offline
Old 02-16-2010, 06:35 AM
  #14
Seems to be the case for me too - I'm sure I won't spend the money if its just the internal LED. Many thanks.
Old 02-16-2010, 07:02 AM
  #15
Weird. I have the same problem, more or less. With mine, the light flickers constantly but doesn't go out.
I find it strange that you need to replace the whole assembly - there isn't just a bulb you can replace? Or perhaps its a fault in the assembly???
audigraffy is offline
Old 02-10-2013, 04:17 PM
  #16
Default FIX
The people Audi has soldering these should be fired. The fix is to take it apart, resolder all the bad joints, and put it back together.
1. With the light switch off, push hard in while rotating clockwise. The switch will pop out.
2. There are spring loaded clips which allow step 1 to happen. Then there are smaller plastic clips (4x in my 2002 Audi A6). Pop the smaller clips with a small flat head screwdriver. That should allow you to take the switch apart. You'll have to rotate the switch while pulling it apart.
3. Pop off the LED pc board using the flat blade screw driver.
4. Inspect ALL the solder joints. I had two bad joints.
5. Solder the joints
6. Reassemble ensuring the LED pc board contacts are tight.
Here are my bad joints:
Here's the switch taken apart:
2002A6Avant is offline
Old 02-11-2013, 05:48 AM
  #17
danzero's Avatar
I have the same issue in my 03 AR. I haven't tackled soldering new LEDs yet, but I found these repair instructions on a B6 forum. I believe the repair should be pretty much the same on a C5.
http://www.vwaudiforum.co.uk/forum/s...h-illumination
danzero is offline
Old 12-21-2015, 04:35 PM
  #18
Default Any idea how to remove headlight switch **** from the switch assembly?
Looking to replace the **** face on the headlight switch assembly. I was able to remove the switch assembly but can not F'n figure out how to remove the actual switch **** with all the worn plastic for replacement....
Any ideas?
Thank you
ThunderHammer is offline
Old 01-06-2016, 09:58 AM
  #19
Any ideas?
Thank you
Most people use black sharpie to cover the wear on black plastic Audi parts. It works ok...
wardhill
01-28-2012 05:36 AM
2000_A4_2.8_Quattro
05-05-2006 11:27 AM
87Paulo
12-06-2005 06:54 AM
AUDIBOI_V8
09-15-2004 11:04 AM
€uroDan
08-15-2003 08:55 AM
Quick Reply: Removing Headlight Switch from Dash
