Replaced Fuel Pump, now ABS and ESP light turned are on!
After replacing fuel pump and fuel relay, my '02 Allroad turned over successfully but then the ABS and ESP light turned on and they had never been on before. During the fuel pump replacement I also replaced a blown out SAP fuse in the E-box and one odd thing while i restored power to the fuel pump was that the passenger seat completely laid itself flat.
My VAG now says "No Response from Controller" on module 03 ABS Brakes. Did the fuel pump replacement screw up my ABS Module?
Sunday,04,June,2017,19:42:12:48188
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 17.1.3.0
Data version: 20170320 DS267.7
Ross-Tech: Home
VIN: WA1YD64B72N070505 License Plate:
Mileage: 167480 Repair Order:
Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005))
Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
75 76 77
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 4Z7 907 551 M
Component: 2.7l V6/5VT G 0001
Coding: 06752
Shop #: WSC 02325
VCID: 4D9F6730876D222952-515A
WA1YD64B72N070505 AUZ7Z0A1963217
18 Faults Found:
17833 - EVAP Purge Valve (N80)
P1425 - 35-10 - Short to Ground - Intermittent
17880 - EVAP Leak Detection Pump
P1472 - 35-10 - Short to Ground - Intermittent
17843 - Secondary Air Pump Relay (J299)
P1435 - 35-10 - Short to Ground - Intermittent
17938 - Camshaft Timing Adjustment
P1530 - 35-10 - Short to Ground - Intermittent
17829 - Secondary Air Injection Solenoid Valve (N112)
P1421 - 35-10 - Short to Ground - Intermittent
17955 - Boost Pressure Regulation Valve (N75)
P1547 - 35-10 - Short to Ground - Intermittent
17697 - Boost Pressure Control Valve (N249)
P1289 - 35-10 - Short to Ground - Intermittent
17529 - Oxygen (Lambda) Sensor Heating Circuit: B2 S2
P1121 - 35-10 - Short to Ground - Intermittent
17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2
P1117 - 35-10 - Short to Ground - Intermittent
17861 - Exhaust Gas Temp Sensor 1 (G235)
P1453 - 35-10 - Open or Short to Plus - Intermittent
17865 - Exhaust Gas Temp Sensor 2 (G236)
P1457 - 35-10 - Open or Short to Plus - Intermittent
16486 - Mass Air Flow Sensor (G70)
P0102 - 35-10 - Signal too Low - Intermittent
17523 - Oxygen (Lambda) Sensor Heating: B1 S1
P1115 - 35-00 - Short to Ground
17527 - Oxygen (Lambda) Sensor Heating Circuit: B2 S1
P1119 - 35-00 - Short to Ground
17522 - Oxygen (Lambda) Sensor; B1 S2
P1114 - 35-00 - Internal Resistance too High
17548 - Oxygen (Lambda) Sensor; B2 S2
P1140 - 35-00 - Internal Resistance too High
16518 - Oxygen (Lambda) Sensor B1 S1
P0134 - 35-00 - No Activity
16538 - Oxygen (Lambda) Sensor B2 S1
P0154 - 35-00 - No Activity
Readiness: 0010 1101
Address 06: Seat Mem. Pass Labels: None
Part No: 4B0 959 760 C
Component: Sitzmemory R1 BF 0102
Coding: 00003
Shop #: WSC 00000
VCID: 2D5F07B0E7AD022972-4B18
No fault code found.
Address 08: Auto HVAC Labels: 4B0-820-043-MY2.lbl
Part No: 4B0 820 043 AD
Component: A6-Klimavollautomat 0105
Coding: 00010
Shop #: WSC 02325
VCID: 5CB99A74CC97BBA1D5-258C
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4Z7 959 655 E
Component: Airbag 8.4E 3000
Coding: 0000307
Shop #: WSC 02335 785 00200
VCID: 51A77B40CB5506C936-5178
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487 J
Component: Lenkradelektronik D01
Coding: 01012
Shop #: WSC 02325
VCID: 336B11C8018954D924-522A
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 981 P
Component: KOMBI+WEGFAHRS. VDO D09
Coding: 06264
Shop #: WSC 02325
VCID: 336B11C8018954D924-515A
Address 34: Level Control Labels: 4Z7-907-553.lbl
Part No: 4Z7 907 553 E
Component: - 2C1A1 D040
Coding: 25500
Shop #: WSC 09999
VCID: 479355186511C87968-515A
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 J
Component: Central Lock/Alarm D35
Coding: 15885
Shop #: WSC 02325
VCID: 30611EC4F09F6FC159-4F02
2 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01561 - Rear left door
59-00 - Can't Unlock
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0102
Coding: 00001
Shop #: WSC 00000
VCID: 2C590AB4DCB70B2165-4B18
Address 45: Inter. Monitor Labels: 4B0-951-178.lbl
Part No: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00102
Shop #: WSC 02325
VCID: 264DF89CC25B3171B3-5196
2 Faults Found:
01349 - Alarm via Theft Warning System; Front
35-00 - -
01350 - Alarm via Theft Warning System; Rear
35-00 - -
Address 55: Headlight Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D06
Coding: 00030
Shop #: WSC 02325
VCID: 0409821414A72361CD-4B64
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 4B0 035 195 J
Component: symphony II NP2 0008
Coding: 00201
Shop #: WSC 00000
VCID: 2753F598C551287988-4ECA
Address 65: Tire Pressure Labels: 4D0-907-273.lbl
Part No: 4D0 907 273 A
Component: Reifendruckueberw. D110
Coding: 22307
Shop #: WSC 02325
VCID: 254FFF90BF5D3A69BA-5178
1 Fault Found:
01477 - System Switched Off
35-00 - -
Address 76: Park Assist Labels: 8Z0-919-283.lbl
Part No: 8Z0 919 283
Component: Parkingsyst. A6 RDW D08
Coding: 01186
Shop #: WSC 02325
VCID: 0205840C0EB32D51FF-515A
Ross-Tech: Home
75 76 77
Coding: 06752
Shop #: WSC 02325
18 Faults Found:
Coding: 00003
Shop #: WSC 00000
Coding: 00010
Shop #: WSC 02325
Coding: 0000307
Coding: 01012
Shop #: WSC 02325
Coding: 06264
Shop #: WSC 02325
Coding: 25500
Shop #: WSC 09999
Coding: 15885
Shop #: WSC 02325
2 Faults Found:
35-00 - -
Coding: 00001
Shop #: WSC 00000
Coding: 00102
Shop #: WSC 02325
2 Faults Found:
35-00 - -
35-00 - -
Coding: 00030
Shop #: WSC 02325
Coding: 00201
Shop #: WSC 00000
Coding: 22307
Shop #: WSC 02325
1 Fault Found:
35-00 - -
Coding: 01186
Shop #: WSC 02325
I found the issue
I'll have to do some troubleshooting to identify which sensor is causing the issue.
AudiSport44
12-14-2006 08:35 PM
Whirly
01-16-2004 07:16 PM
