Replacing (upper) control arms / Air line disconnect
Hi,
on my 2004 allroad I have to replace the control arms. basically this seems to be straight forward, however I'm thinking about the upper control arms. I have only the descriptions for replacing the control arms on A6 4b models having standard springs so I'm asking how to remove the air line safely from the air spring and putting it later back on without damaging the air line and / or its connection point on the strut. Or is there an (easy) way of installing new upper control arms w/o removing the whole air spring assembly?
And are there any other differences to the standard A6 when replacing the control arms (incl. lower ones)
Regards
Bernhard
Regards
Bernhard
Banned
best way to replace the uppers is to pull the shock assembly out
also, make sure the car is on the ground before tightening the upper c-arm bolts.
to disconnect the air line, take a 10mm wrench and loosen the fitting; when putting back, put a couple wraps of teflon tape on it
Thanks for the answers
so a standard o ring will do the job? Seems this set includes the correct type?: http://cgi.ebay.de/263016304689
Or do I need something special here?
Banned
the teflon is for the threads, been there done that many times
your o-ring idea, while good, wont work in this instance
here is the video from arnott on changing out the airspring https://www.youtube.com/watch?v=LBlS...ature=youtu.be
N-17 air hose connector
Hi,
Regards
Bernhard
Regards
Bernhard
eBay. The
econnelle
17
05-03-2008 08:10 PM
MingsS4
07-10-2007 04:13 PM
