RESOLVED - Water in Passenger Side (front and rear) after rain
Okay, I'm writing this for the benefit of others who may encounter this situation.
My 2005 allroad 2.7T Auto was parked in the driveway when there was a heavy thunderstorm. Next day morning, I started the car for work, din't notice anything unusual and hit the roads. After the first mile, I was in a signal and was pulling up on green and there was a thud and a jerk, same time, I heard splashing water on the rear passenger side and multiple bleeps and blinking lights on the dashboard. I think the car went into limp at that point (I continued driving for fear that if I stopped I may not be able to start again - look at my other thread on this). After reaching my destination (work), I checkout out
What I learnt 1. Do not lose hope if your TCM or ESP module is wet and is not working. Just give it some time to dry and keep trying for a few days. It started working for me after 3 days. I was blessed to have another car for work that I had the liberty to wait and let it dry. 2 Reading the forums, there seems to be a confusion on why ABS light is glowing while the ESP module is wet? I initially thought what was higher up in the passenger foot-well is the ABS module, but I was wrong. The ABS module is near the Windshield wiper and it was dry and was good. Looks like when the ESP module gets wet, it may also throw the ABS light. 3. I did not open the metal housing on the TCM module even though it remained soaked under water for about 24 hours. 4. My sunroof drain was not blocked. The drain under battery is fine. 2 years back I had a basket ball hoop fall on my windshield after a thunderstorm and I had hired someone to replace the windshield. I think the plastic cladding under the windshield is not secured well enough that water entered it and into the cabin air filter housing. This is a theory as I see the sponge in the filter housing to be completely wet and deteriorated. There is also a crack on the filter housing base. Not sure whether water would have entered if there was not there. I can also feel some wetness behind the glove box when I put my fingers from under the passenger foot-well. I'm continuing to test this theory to find the reason why water entered. Tips from others are welcome. I'm not very mechanically inclined, just can handle wrenches. I may be doing some silly things here, so, let me know if I'm missing anything here. |
Check the little ledge at the bottom of the windshield. It's supposed to carry water off the glass to the side. You've had the windshield replaced. The person who put in the new one may have filled that ledge with adhesive. It needs to be removed or flooding can occur again.
No, I think you found the problem, my car had a similar issue and the crack in the bottom of the cabin air filter box is where it was coming in.
Do you know a good place not too expensive to get my 2.7t engine reassembled
I need to find a good mexhanics in orange county california can anyone help
