Secondary Air Injector "Abort Result" -70% flow
Well the code is back on my 2004 Allroad for the SAI. A couple years ago I did the rebuild that Halik wrote up in 2008 with about one year's success. Now I've got -70 and -80% flow and can't pass the readiness test to get new tabs. (The pump does blast a goodley amount of air when hooked direct to the battery). I did patch one of the hoses between the pump and the comnbi valve with galvanizing tape when it cracked. Wondering if anyone has advice on where to tear into this issue first? (Also wondering if the "System Not OK Result Lambda Control" error is worth freaking out about.)
Thursday,18,January,2018,10:47:07:31538
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.8.1.0 (x64) HEX-NET CB: 0.4409.4
Data version: 20171130 DS276.6
Ross-Tech: Home
Dealer/Shop Name: JHM
Mileage: Repair Order: 001
Readiness Status: 0000 1000
Exhaust Gas Recirculation: Passed
Oxygen Sensor Heating: Passed
Oxygen Sensor(s): Passed
Air Conditioning: Passed
Secondary Air Injection: Failed or Incomplete
Evaporative Emissions: Passed
Catalyst Heating: Passed
Catalytic Converter(s): Passed
Address 01: Engine (4Z7 907 551 S)
10:53:15 Group 107: Lambda Control
680 /min Engine Speed (G28)
25.0 % Lambda Control Bank 1 (Average)
25.0 % Lambda Control Bank 2 (Average)
10:53:58 Group 041: Lambda Control (Lambda Sensor Heating Bank 1)
0.30 kOhm Resistance Bank 1 Sensor 1
Htg. S1 ON Heater Condition Bank 1 Sensor 1
Resistance Bank 1 Sensor 2
Htg. S2 OFF Heater Condition Bank 1 Sensor 2
10:54:01 Group 041: Lambda Control (Lambda Sensor Heating Bank 1)
10:54:57 Group 036: Lambda Control (Sensor Readiness - After Catalyst)
0.490 V Sensor Voltage Bank 1 Sensor 2
Test OFF Result Lambda Availability
0.480 V Sensor Voltage Bank 2 Sensor 2
10:55:38 Group 034: Lambda Control (Lambda Sensor Aging - Bank 1 Sensor 1)
240.0°C Catalytic Converter Bank 1 Temp.
0.48 s Dynamic Factor Bank 1 Sensor 1
Test OFF Result Lambda Aging
10:56:45 Group 043: Lambda Control (Lambda Sensor Aging - Bank 1 Sensor 2)
10.0°C Catalytic Converter Bank 1 Temp.
0.395 V Sensor Voltage Bank 1 Sensor 2
Test OFF Result Aging Check
10:57:15 Group 046: Lambda Control (Catalytic Conversion Test Bank 1)
0.26 Catalytic Conversion Bank 1
Test OFF Result Cat. Conversion
10:58:14 Group 077: Emission Reduction (Secondary Air Injection System Bank 1)
3.33 g/s Mass Air Flow (G70)
-80.5 % Secondary Air System Air Mass
Abort Result
11:01:24 Group 077: Emission Reduction (Secondary Air Injection System Bank 1)
Abort Result
11:01:24 Group 078: Emission Reduction (Secondary Air Injection System Bank 2)
3.39 g/s Mass Air Flow (G70)
-70.3 % Secondary Air System Air Mass
Abort Result
Ross-Tech: Home
Abort Result
Abort Result
Abort Result
Banned
i eventually pulled everything sai related out on my allroad
you might be able to get away with that in your location, if we knew where that was . . .
if you need parts, i still have most of the parts and plumbing boxed up ready to ship
Nichole77
12
04-04-2016 01:16 AM
