suspension sometime leak..sometime not.., sometime pump up quick..sometime so slow..
front left suspension sometime..do not leak over nite.., sometime leak...wondering why ?
sometime..i hear leaking noises..sometime without.. sometime..take long time to pump up... if it is a fauly spring..why..sometime..it does not leak at all ? |
Re: suspension sometime leak..sometime not.., sometime pump up quick..sometime so slow..
It will leak on level 1 and 2 but not on 3 or 4.
It will leak when it's cold, not when it's warm. Sometimes it will raise a level in 15 sec. but other times it takes 55 sec. Sometimes you will hear the compressor when there's no change in levels. Sometimes you raise from level 1 to level 4 and the compressor never comes on. Are these the things you refer to? I think they all occur w/ this car. If you have a leak than you really do have a leak but it is not always obvious (Level 3&4, warm weather) |
yes..yes..it is what happened to me..
i had jsut order arrnots...and wondering what else..it can be.. |
Explanations..
If it leaks on L1 OR L2 OR L3 but not on another level, you have a hairline abbraision leak. This is at the fold over of the rubber for the given level. WHen you change the level, the tiny leaks..seals itself.
Its still a leak.. GREEN SLIME has been shown to repair these. Do a Search. |
Re: Explanations..
that..what i had throught..but..when it is expanded..at higher level..the anykind of crackline should also expand too..should leak..too.. thx..i shall take a look "GREEN SLIME"
Sometimes....
...you feel like a nut...
<img src="http://thejoggler.googlepages.com/Almond_Joy.jpg"> ...sometimes you don't... <img src="http://www.viewpoints.com/images/review/2008/42/18/1202777352-66827_full.jpg"> Sorry...in a weird mood today... |
Nice. :oP
