TCM(Transmission Controll Module). Any one know where its ......
Located. 2002 Allroad. Gonna do the Tip chip thingy. To save the local installer the module removall time I was planning on removing it myself. I thought it was behind the passenger foot well trim. However after removing the panel I found nothing but a bunch of plugs and connectors. Any help in locating the module would be appreciated. Thanks...............
Your close...
It is under the passenger foot area.
Almost under the seat itself.
Make sure you put the passenger seat the entire way back, and then pull the carpet up.
You'll see a little black box, bingo that's it.
Should be in the same place as always - under the passenger floor panel
remove the plastic trim on the inside of the door to be able to lift up the carpet, there you'll find it after removing the cover plate, in other words: where the pasenger usually has his feet, below is the TCU.
StarryTripper
12
12-16-2021 02:34 PM
first.octopus
08-08-2015 09:34 AM
Agent Orange
10
10-29-2002 05:29 PM
