Two warning lights: Dynamic Headlight Dimmers and Self-leveling Suspension
Both came on at the sametime. Can't run codes until tomorrow. Any idea what this my be, car seems to be preforming fine. 91k and running strong.
Had same 2 come on last month...
Turned out to be some sensor for the self-leveling suspension was burned out. Mine is still under warranty, but I think i rememeber seeing the chargeback to Audi being somewhere betwee $300-$400. The replaced part fixed both. If you need more detail let me know and I'll run up and get the sheet showing exactly what they replaced. My air suspension does work much better now that they replaced it. Hope this helps.
Re: Had same 2 come on last month...
Would you, I'm out of warranty and would like to repair it myself or at least be aware of the problem if I need to send it in for repair.
It isn't always a suspension problem, The suspension light came on when my headlight sensor went to
ground. You are gonna want to read the error codes from your headlight and suspension modules with a vag and that should let you know what is going on. In my case a clearing the code fixed all.
atomasi
Audi allroad
10-15-2010 10:31 AM
sugaryling
Audi allroad
13
06-12-2008 10:35 PM
