VAG-COM and Autoleveling Headlights - FYI
In case any of you try this on an '03, an important step must be added when the car is relearning the newly adjusted headlight reference you enter - the car must be running. The baseline will not reset if the ignition is simply turned to the "on" position but the car is not running, and you will throw a code.
Link to the original article is provided.
'03 with tip
chips, bars and boots.<ul><li><a href="https://www.audiworld.com/tech/misc29.shtml">https://www.audiworld.com/tech/misc29.shtml</a</li></ul>
'03 with tip
O.ct Stage 2, 93 octane...
tip chip and ECU chip. If you search the posts I know a few ar guys have had a problem in the past with an O.ct upgrade/install, but I am happy as a pig in slop with this sytem and my Milltek cat back. Chips are good.
D Spin
06-11-2007 06:50 PM
CTAUDIDUDE
28
11-07-2006 06:00 PM
vegasS4
10-20-2005 09:58 PM
Auto Union Jack
07-04-2001 09:58 AM
