Won't raise up to level 4??
#22
Last thing: When you dismenat the compressor hade notice the one_way valve on the piston top hade.Clean it in the sealing area with a solvent and sheet of paper..... see attached file
#23
Pressure ignition off - 3,20 BAR
Pressure ignition on - 3,2 to 3,58 BAR
i relember a few years ago to see values like 10 and 11 BAR.
compressor is the root cause or could be something else like the reserve air tank or the control module?
#25
There are two types of compressors that look the same, For two wheels air suspension 12.0 Bar max and for 4 wheels a air (Allroad) PN\ 4Z7616007A 16 Bar max For better understanding the allroad air suspension system google for SSP 242 and 243
#27
When I connect the Vag Com, module 34, I should see the air tank with 10 to 12 BAR. Correct?
Regarding my need to buy a new compressor, until now I bougth everything to Air Suspension Shop but the actualy have the Wabco compressor for 350€. On eBay I saw compressors for 200€ but I don't know their quality. What do you recommend?
#29
Pressure leaks?
#30
I’ll try to mesure the pressure riding over 50km/h
the system don’t to rise to high 2. I press the upper botton, the green ligth is on when I press but after do nothing.
same behaviour when riding over 35km/h and try to press upper boton.
it’s like someone wrote the same behaviour here, but in his case after cross a lot of water place the system start working normal again.
what could be the root cause that a bath of water solved?
