Won't raise up to level 4??
Old 09-16-2018, 02:43 AM
  #41
Hugo Pedro's Avatar
youtube video mentioned...
Old 09-22-2018, 12:34 PM
  #42
Hugo Pedro's Avatar
Any of you eard about this case?
Old 09-23-2018, 01:50 AM
  #43
amiram's Avatar
Did you check the compressor that hi can reach the 16 Bar ? About the "solution" Check to see if it fixe your issue. If not look for a pressure leak from the system
Old 09-23-2018, 02:46 AM
  #44
Hugo Pedro's Avatar
Compressor is new, check for leaks performed and no leak was found. The acomulator seems to be setup to keep only 1,6bar. Very strange
Old 09-23-2018, 03:15 AM
  #45
amiram's Avatar
The system checks the air pressure in several places (and shows different results)
. In each of the 4 corners. In the pressure tank. And on the red pressure line ( See attached file ) to make sure there are no leaks from this area
Old 09-23-2018, 11:13 PM
  #46
Hugo Pedro's Avatar
I performed the water & soap test and no leaks. I had leaks in the past and the suspension decrease high over nigth. 2 days stoped and didn’t decrease high. Isn’t the g291 sensor who mensure the pressure for the 5 lines?
Old 09-28-2018, 04:35 PM
  #47
4xaudi's Avatar
Yes the G291 is the presure sensor. It is inside the valve block and is not replaceable. I would check the wiring from the valve block or the valve block may need replacing.
Old 10-01-2018, 11:37 AM
  #48
Hugo Pedro's Avatar
Any ideas? The wires seems to be ok. I’ll wait until the weekend and i haver to tale a decision if I’ll take it to AUDI store. It Will be expensive but I need the problem solved.
Mrfantastik
09-06-2018 07:14 AM
Chris M.
04-15-2015 07:12 PM
Mark Jacobs
Audi allroad
28
01-25-2013 07:40 AM
Mark Jacobs
Audi allroad
11-20-2006 11:07 AM
Repoman
Audi allroad
10-14-2002 04:35 PM
Quick Reply: Won't raise up to level 4??
