Yes, you read correctly! We now have footwell LEDs for every single Audi model/trim o
10 Attachment(s)
Yes, you read correctly! We now have footwell LEDs for every single Audi model/trim on the market.
They come in bright clean white (brighter than OEM) - Red, white. Some models have multi-color and rear/front conversion kit. We made an easy to follow list - all you have to do is look to see what style you have in your car! Attachment 105088 These LEDs are 100% dimmable through car's MFD (multi-function Display) Works without errors NO SPLICING NO WIRING Fits directly into the Audi OEM housing! Halogen Model Attachment 105098 Single Color (Clean bright white, red or blue): 2pc 6 LED Wafer Footwell set in Crisp White/Red/Blue Fits: Audi Models with the 194 wedge footwells | deAutoLED Multi-color footwell Model (over 15 colors with a click of a button): Remote Controlled Color Changing Footwells - Plug And Play LED Bulbs[194/921] fits: MK6 GTI | deAutoLED NEW Rear & Front Footwell Conversion Kit (works if you have only front footwells): Front & Rear Footwell LED Conversion Kit Fits: All Volkswagen/Audi with 194 Front Footwell Housings | deAutoLED ------------------------------------------------- Attachment 105099 Single Color (Clean bright white, red or blue): New LED Footwells for Audi models that are equipped with OEM LED Footwells | deAutoLED Multi-color footwell Model (over 15 colors with a click of a button): Remote Control Color Changing Footwell LEDs Fits: All Audi & Volkswagen Models | deAutoLED NEW Rear & Front Footwell Conversion Kit (works if you have only front footwells): Front & Rear Footwell LED Conversion Kit Fits: All Volkswagen/Audi with Pin Style Footwell boards | deAutoLED ------------------------------------------------- Attachment 105100 Single Color (Clean bright white, red or blue): Footwell LED - Rectangle Black PCB (4 Prong model) fits many Audi Models | deAutoLED ------------------------------------------------- Attachment 105101 Single Color (Clean bright white, red or blue): Footwell LED - Square White PCB (4 Prong model) fits many Audi Models | deAutoLED |
Thanks for the support - email us at anytime if you need any help finding the right LED for your car:
Support@deAutoLED.com |
4 Attachment(s)
See why our interior LEDs are so popular!
-Fade in/out like OEM -Clean white color temp -WON’T stay dimly lit when your car is off -No spotting with our lighting -Our product has Frustration free packaging – every LED comes in an anti-static bag that is easy to open. -All interior LEDs are labeled for each location (we don’t simply toss the same looking LEDs in a bag and make you figure it out). Our LEDs look different for each area of your car. www.deAutoLED.com -Choose from red white or blue footwells Red is one of our most popular footwell colors for good reason: Red has great night vision properties and many studies show that it reduces anxiety and stress. Attachment 105084 Attachment 105085 |
Faster shipping than many Amazon Prime products! :)
We ship daily with a tracking # from the US - we provide customer service 24/7 - our LEDs are tested and made to work in your car! www.deAutoLED.com Support@deAutoLED.com FB group for support/chilling with customers like yourself: https://www.facebook.com/groups/deAutoLED/ |
20 Attachment(s)
White/Yellow/Halogen/Strobe/Flash plug and play fogs:
Dual Color LED Fog [1 bulb 2 colors] Choose between a Clean White & Hyper 3000k Yellow at anytime | deAutoLED -Plug and play -Error free in most cars. Some might need extra resistance - we sell a new design that DOES NOT require you to attach it to metal. It is compact and easy to install - simply plug into OEM adapter and our LEDs (100% plug and play NO splicing design) -Easy to switch between each color – simply turn OEM fog switch off/on - normal cycle: White - yellow - halogen - flash/strobe -BRIGHT – this is not just a novelty bulb -COLOR MATCH - these match our LEDs/HIDs in 5500K White mode -HYPER YELLOW - these are a true hyper yellow mode you normally see with yellow lamin-x covering the lens **this is NOT a cover around a bulb or a cover on your lens - this is brand new LEDs that are a super hyper 3K yellow** -SAFE – more light on the sides and down the road when dark or in bad weather conditions -The Hyper Strobe / Flash – this does not simply "flash" but has a strobe/flash pattern like an emergency vehicle - you can choose between 4 different modes - video of mode 1: https://www.youtube.com/watch?v=T-fex4DUPSg 3 colors: -Super Hyper 3000K Yellow that many like for bad weather: Rain, snow, fog -Clean White 5500k that matches our LED & HID Headlights -Halogen 4300k that matches OEM Video cycling quickly through colors AND different strobe/flash features: https://www.youtube.com/watch?v=bQG0gRKGFk0 INFO: -THESE ARE BRIGHT! You might have seen the novelty fog LEDs that can turn yellow/white on amazon and ebay by the thousand that don't provide much useful light, trigger errors, die quickly, or simply don't work correctly. Our new model fixes every issue you might've seen and simply works. -These produce MORE LUMENS than many standalone single color white fog LEDs on the market -Not only are these great for safety, daily use on dark roads and bad weather this will amaze at any car show and you will have your friend asking how did you do that and where can I get those anytime you use these fogs! *Please note these ARE error free but in strobe/flash mode they can trigger an error in some car models – errors WILL clear once you go back to a solid color. Attachment 104952 Attachment 104953 UPDATED FAQ Is there a lifetime warranty? YES! As always this comes with a True Lifetime Warranty! ---- Will your fogs keep changing colors if you use them as cornering lights? The answer is no as this only changes by turning your fog switch on/off. If you are using your fogs as cornering lights it will always be the default color of white. ---- How does this work with the coming home feature? This works just like OEM. It will always be the default color of white. ---- What if I have the yellow feature on and turn off my car; will it then go into the next color when I turn it back on? The LEDs will always revert back to the default color of white. Then simply turn the fog on/off for your desired color: yellow/halogen or strobe/flash mode. ---- Can these turn 360 degrees? Yes, these are a fully adjustable design so you can turn these 360 for the best beam angle. ---- Are these as bright as your single color de360 fogs? While not as bright lumen wise it comes very close - many people that have switched to our single color white to our dual color yellow/white LED fog kit have not noticed any difference in visibility. As we said this is NOT a novelty yellow/white you normally see. This is meant to be used to help with your visibility. ---- Can you bypass the strobe feature? Yes, this works when you turn the fogs on/off quickly. If your next mode will be strobe simply shut off the fogs for a few seconds and then turn it back on and it will go back to the default white. -- Attachment 105060 Attachment 105061 Attachment 105062 Attachment 105063 Some more fun shots - in the rain: Attachment 104954 White / the super hyper yellow - this will be a hyper lamin-x yellow without the cover! Attachment 104955 Attachment 104956 And switch back to clean white: Attachment 104957 |
2 Attachment(s)
Are you ready for Halloween, Fall and the winter?
Get ready with Orange footwells Perfect Fall weather to install LEDs for the darker winter nights www.deAutoLED.com Attachment 105024 |
2 Attachment(s)
