Best Range - Real World
#42
Charging to 100% is not advisable because then you’re not using the maximum recuperation the car can do. This will force you to use the mechanical braking which lowers your efficiency, hence the poor consumption numbers. And reaching the same consumption every day makes the car update the range downwards. In my test drive I have seen that maximum recuperation starts around 80%, I guess that is why it is recommended to charge only to 80% every day, so that you can always benefit from the maximum recuperation which in return will give better range.
#43
Yes, but what charging speed does the battery has when it is almost full? To avoid degradation charging speed is limited to about 50kw. For same reason is the recuperation limited while the battery is too full. If I remember correctly, on full recuperation the battery is charged with around 200kw and this only starts happening when the battery is around 80% charge. There might be a linear increase in recuperation power between 100% and 80%, but I didn’t checked precisely. Bottom line is constantly driving with full battery is not economic at all and the range displayed by the car will drop.
#44
Curious to hear about any longer distance trips this Memorial Day in the e-tron. Does the trip planner work well planning your charging stops? How was your experience? Have a safe holiday weekend!
#46
Sweet looking car. BlackOptic, your e-tron is ready!
#48
Pretty encouraging consumption data. As long as you're under 41 kWh/100 mi you're beating the EPA number. BTW, which drive mode are you typically driving in? I assume you're not prone to hypermiling
#49
Most of the weekdays trip I posted are 25 mi. one-way commute. 17+ of those miles is on Merritt parkway (many up and down hills) that are driven at around 62-70 mph.
