To buy a 25kwh Dc and above?
So let’s assume that the cost we’re not prohibitive, and powers we’re available for Level 3 at 25 kWh and above...
Due to the fact there are no level 3 chargers within a reasonable distance, and time is a factor of life...if you wanted to install a level 3 or even partner with a provider who would entertain your dream...where would you start? is a 25kw DC charger affordable on any sane level and will it achieve our goal of fast charging? If not, at what level does level 3 make any affordable sense, Especially when you factor in the time to charge? I don’t know if 25 or even 50 would be anough to accomplish my goal, as I’m not an electrician, etc. however, I did stay at a holiday inn last night.... |
Having DC charging setup at your home would be pretty cost prohibitive, not to mention the permits that you would need and most residential areas are not equipped to have a level 3 charging station installed. Also, in the long run, the slower rate of level 2 charging is better for overall battery health. Long story short, it's really not feasible.
Thank you for your input. Actually, my home is above a commercial building that we own, and separately near by I have a second commercial building where both are possible.
As for cost, that’s the question. There’s a limit to what’s reasonable, but if it’s the only level 3 in our corridor, then it maybe makes sense. Let’s assume that the nearest 3 phase power was within reasonable reach, what type of dc charger would do the trick? Would a dc 25 be enough or it that pissing in the wind. Charger alone are we talking 10k and above? |
Have you contacted electrify America ?
https://www.electrifyamerica.com/submissions At this time, we welcome the following input: 1. Specific site locations – Specific site locations you would like to nominate for consideration in Cycle 2 infrastructure investments. |
This may be of some help: https://www.plugincars.com/ev-chargi...usinesses.html
TLDR: "Commonly, installing a networked Quick Charger costs between $600 to $1,800 per foot from the nearest utility transformer. In other words, a Quick Charger installed 20 feet from a power line will set you back as much as $20,000 to $30,000. DCQC equipment itself costs about $10,000 to $40,000 before installation."
Originally Posted by MKSurfPhoto
(Post 25316332)
https://www.electrifyamerica.com/submissions At this time, we welcome the following input: 1. Specific site locations – Specific site locations you would like to nominate for consideration in Cycle 2 infrastructure investments. Our town, even if it were not on my land, makes total sense for the location of where we are in relation to travel points. We are about 1/2 way between Albany Ny and Plattsburgh. We are directly off I-87 Northway sandwiched between two or more easy access exits and our main road through town runs parallel to the Northway. We have a solid economy, and I sound like a stinking politician which I’m not so I’ll stop. |
Originally Posted by EditionOne
(Post 25316338)
Originally Posted by suprspdway
(Post 25316323)
The ChargePoint 62.5 KW station is like 39 grand. You can additionally hook it to a Power Cube that has 37.5KW modules that will power multiple "pumps" (so you can charge at 150KW or above). The major problem is that it takes 400V 3 phase, which no one has at home.
