Drop in Range?
Drop in Range?
I purchased my 2019 e-tron in June 2020 and when I charged it to 80%, I typically had a projected range of approximately 180 miles. However, recently my 80% projected range is 160 miles. I live in a very hot climate so the weather now is more ideal for battery life than in the summer; furthermore, my mix of driving has not changed. I wondering if this "drop" in range should be something to worry about? I only have 2,500 miles on the car so I don't have a lot of data on this vehicle. What do you think?
The range estimate is just that -- an estimate. We call it the "guess-o-meter" on this forum. The range estimate is based on your recent driving behavior and energy consumption. A change of 20 miles in range is really not much when it comes to the range estimator.
If you're worried that something is wrong with your e-tron -- it's fine, your e-tron is working as designed. You haven't "lost" range, it's just that the parameters going into the estimation have changed. This can be everything from driving habits, to temperature, to tire pressure, etc.
If it’s a genuine degradation over time you’ll see the daily efficiency slowly and consistently deteriorate, rather than a few odd trips. As mentioned this could be as simple as tire pressure.
I would not sweat anything that the GOM (Guess o meter) predicts when you first turn the etron on. Especially if you know your own driving style. The reason being that it takes into account your previous driving habits and applies some sort of algorithm to your planned route. While that is all very handy, it is often not accurate, especially when you first set out or if you have changed loads, or the weather has changed. I find that the etron logic is pretty good for making quick estimate adjustments based on elevation and heat in my case, but it often takes into account something from my most recent trip which will throw off the calculation for the next trip until it adjusts again. (Some times I'll take my trip home and just say eff it and max the AC for an hour commute. Sue me, it is way over 100 outside. But that highly inefficient logic is there at the start of my next trip.)
Just an example, these are data from arbitrary daily city driving within the same area near my home.
There is a decent variation depending on the traffic conditions, my mood and how I feel like driving, etc. I would not be able to point out anything notable between any of these particular trips from memory, just an array of normal daily errands.
If every day were 59.5 kWh per 100 miles my estimated range at 80% charge would be 142 miles.
If every day were 35.7 kWh per 100 miles my estimated range at 80% charge would be 238 miles.
I think right now the range estimator is telling me 172 miles at 80% charge. It continues to fluctuate up or down a bit every time I take a trip.
e-tron_Ron (11-24-2020)
So is there a way to check degradation?
Not that I'm aware of. I'm sure the battery is subjected to a series of QA tests to certify its charge/discharge capacity, but you would have to duplicate those conditions. For that matter, what are the conditions the EPA uses? I guess you can only hope that what seems to be lost now, comes back later!
