GVWR?
To those who are lucky enough to already have their e trons, can you take a look at the door jamb label and see what the official GVWR is? For tax purposes, of course. :)
Not much help for taxes other than the credit. Maximum depreciation for an SUV under 6,000 lbs. used 100% for business is $18,000. Over 6,000 lbs. it's $25,000. The e-tron is 5,489 lbs.
The etron GVWR is 6200+#.....it rings the bell
Originally Posted by suttoni
(Post 25315049)
https://www.mileiq.com/blog/section-...les-deduction/ I have not seen the GVWR of the e tron posted anywhere, but on Audi's media website there is a technical datasheet that listed it as 6900 lbs. That was current as of January 2019, but probably for the European model. |
Hmm! Good point.
Normally i write off the mileage but 100% depreciation maybe a huge advantage. Are we confirmed at over 6000? |
I just checked my E1... it is 6,978
Originally Posted by mjeaton
(Post 25315366)
Originally Posted by Francis Y.
(Post 25315109)
This is not true. The maximum depreciation for vehicles with GVWR over 6,000 lbs. is 100% of the cost (if used 100% for business).....
I have not seen the GVWR of the e tron posted anywhere, but on Audi's media website there is a technical datasheet that listed it as 6900 lbs. .... However - there are two roadblocks here. 1. If you noticed in the article you quoted, a qualifying SUV over 6,000 lbs must be built on a truck chassis. Is e-Tron based on a truck? 2. The bigger tax issue is trying to claim a 100% writeoff of an $80,000 car as being "ordinary and necessary" under IR Code section 162. That section also requires business expenses to be reasonable. This would be difficult to prove with the e-Tron in virtually every business scenario. The writeoff would probably be limited to the price of a similar sized SUV over 6,000 lb. based on a truck chassis which was in a non-luxury price range. |
(Post 25316733)
Yes, OK you are right on the weight. I picked up the 5,490 lbs. from the e-Tron's published weight unloaded & without a driver. The 6,901 lbs. is the GVWR.
However - there are two roadblocks here. 1. If you noticed in the article you quoted, a qualifying SUV over 6,000 lbs must be built on a truck chassis. Is e-Tron based on a truck? 2. The bigger tax issue is trying to claim a 100% writeoff of an $80,000 car as being "ordinary and necessary" under IR Code section 162. That section also requires business expenses to be reasonable. This would be difficult to prove with the e-Tron in virtually every business scenario. The writeoff would probably be limited to the price of a similar sized SUV over 6,000 lb. based on a truck chassis which was in a non-luxury price range. https://www.watsoncpagroup.com/secti...iness-vehicle/ That CPA group does not describe the vehicle as being required to have a "truck chassis". Also, multiple websites list the Audi Q7 as a qualified vehicle and Audi does not build them on a truck chassis, do they? As to your second point, it is debatable. Basically, I'm not giving any tax advice (obviously), so YMMV. |
