Home Charging Options
#93
Thanks,
i have a retail store with what will soon be a 200 amp service (up from 100). I’m considering the ways to add the fasted available charging for our needs, and it looks like I’d be limited to level 2? From what I’m hearing, the j1772 plug (and the onboard Etron unit are the two limiting factors to going higher capacity?
so if I were to be willing and able to spend slightly more to go to Really bulk up the possibility, what would I be looking for in a faster charging unit?
https://www.deltaww.com/Products/Cat...ame=DC+Wallbox
#95
I you actually need a faster charge rate, you can buy the Delta charger that is being installed at Audi dealers. It's 25kw DC via the CCS connector.
#96
The three input power options are listed at that link (240Vac1Ph, 208Vac3Ph, and 480Vac3Ph). I don't recommend anyone trying to use this at home as they spec a 165 amp circuit for 240Vac1Ph.
#98
#100
