Juice Box Pro Not Charging
Old 05-06-2019, 04:19 PM
  #11
sallgeud's Avatar
I had this issue at first. It turned out I didn't insert the juicebox plug far enough. Make sure you hear it click.
Old 05-06-2019, 05:50 PM
  #12
jeffbtx's Avatar
Originally Posted by schalliol
Ours didn’t clock, so that could be it. I think we did what we could but will try again. Thanks!
Doesn't the JuiceBox have a visual indicator (light) that tells you the plug is connected?
Old 05-07-2019, 07:07 AM
  #13
schalliol's Avatar
Messing around more, we did get it finally to click and charge. It wasn’t as simple as I thought for a standard connector. I found it interesting the app would say plugged in but apparently still not be plugged in enough to charge. Thanks for the encouragement to keep trying!
Old 06-18-2019, 03:55 PM
  #14
FFT
FFT's Avatar
Having the same issue with my etron. Juicebox will not charge after a week although plugged in and everything else functioning. Just got them to send a replacement but very frustrating.
Old 06-19-2019, 03:20 AM
  #15
Southpondcamp's Avatar
I have a different issue...mine charges fine (definitely have to firmly click it in place) but I couldn't get it to connect to my home internet. I finally gave up in frustration and semi-delegated to my husband who hasn't had time to mess with it. The available instructions are not helpful...🙄
Old 06-19-2019, 08:14 AM
  #16
theo1000's Avatar
I'm having trouble getting mine to unplug. The exact sequence to unplug is still a mystery. It takes me a a good 2 minutes of fiddling and locking unlocking to get the JB plug to release. Baffling....
Old 06-19-2019, 08:20 AM
  #17
Hmm. That hasn't been an issue for me. I press the etron door button and give it a few seconds for various clicks/whirs-- usually I'm putting my purse/work bag/coffee in the car at the same time in the morning so I'm not really paying attention--then I unclip it and off I go. Sorry you are having trouble!
Old 06-19-2019, 08:25 AM
  #18
MileHigh e-tron's Avatar
FWIW I recently had this JB installed in my garage in anticipation of getting my e-tron sometime in the near future. Currently we’re using this EVSE to charge my wife’s Prius Prime. We have not experienced a single problem with it. The vehicle gets charged quickly, the box is always connected to my home WiFi network and always notifies me, when charging starts and stops. I hope I’ll not be running into compatibility issues with this EVSE and the e-tron - if that’s even possible.
Old 06-19-2019, 08:33 AM
  #19
TonySCV's Avatar
No problems with the JuiceBox 40 on a 50A circuit here. I had a little trouble at first with getting the connector to "click" properly as well, however now that I am used to how it works - no problems.
Old 06-19-2019, 09:49 AM
  #20
mmulet's Avatar
I haven't had any issues with my JuiceBox either; what I found helps is pressing the e-tron door button, and then waiting to hear when it is released. It is kind of quiet but you can hear it, then you can remove the connector.
Quick Reply: Juice Box Pro Not Charging
