Maintenance schedule and Audi Care
If you debate on wether to get the Audi Care. Here are the maintenance items that stands out (to me). Source to the April 2019 copy of the officiel maintenance schedule ( starting on Page 4 ) 2019 Audi Maintenance Schedule - All models ( April 2019)
*** Connected box battery - Check state of health with Vehicle Diagnostic Tester in Guided Functions
*** Cooling system for electrical components - Check coolant level and add if necessary according to procedure in ElsaPro
**** Front axle drive - drain coolant (with small cover removed)
**** High voltage cooling system - Check for damage and leaks
**** High voltage system components - Check for damage and leaks; check cables and insulation for damage and proper mounting
**** Motor compartment - Check transmission, final drive, and steering for leaks
** Brake fluid - Change
** Dust and Pollen filter
*** Fragrance Cartridges - Change (if equipped)
**** Rear axle drive - Replace coolant cartridge (with cover removed)
legend:
** easily DIY.
*** potentially only Audi dealer will know what to do.
**** IMHO, may risk warranty coverage, if not completed.
legend:
** easily DIY.
Looking at the schedule. We really only need to bring the e-tron in for service every 2 years. The annual Minor Maintenance items are all "Checks" and "Inspects", which I can do myself - I have a 4-post lift that can handle 9000 lb
billy2001Q
11
03-08-2005 04:55 PM
mrvirgilg
01-27-2005 12:45 PM
MYTTS
09-04-2004 08:54 AM
