AudiWorld Forums
AudiWorld Forums (https://www.audiworld.com/forums/)
-   Audi e-tron / Q8 e-tron (https://www.audiworld.com/forums/audi-e-tron-q8-e-tron-232/)
-   -   problem setting charging target (https://www.audiworld.com/forums/audi-e-tron-q8-e-tron-232/problem-setting-charging-target-2972197/)
avie 05-12-2019 12:08 PM
I'm trying to set the charging target on my Edition One. When I go into the screen to do this it shows as already set to 50% (which is wrong since it charges to 100%). If I try to change it either using the +/- buttons or dragging to a new value it always snaps back to 50%. Anyone else seeing this and/or ideas to fix it?
anemeth 05-12-2019 12:48 PM
Are you setting a target on the screen while you charging? If not, maybe it works when it is charging only (it is just a guess).
avie 05-12-2019 02:43 PM
I've tried it both while charging and when not charging.
Oh, I should have mentioned. Even though it says the limit is 50% it charges to 100%. Thankfully it's not actually being limited to 50%!
Reliantg 05-12-2019 04:45 PM
Are you using advanced home settings that override the regular charge target?
alexlear 05-12-2019 05:27 PM
I had this happen yesterday after deleting a location charging profile. Lock the car and let it go to sleep (~30 minutes). Then come back and it should let you change it correctly. I think it's a bug.
avie 05-12-2019 08:06 PM
Nope. No advanced settings turned on.
avie 05-12-2019 08:07 PM
I tried this and it did not help. There is definitely some kind of bug here!
avie 05-13-2019 06:56 PM
I think I found a workaround. I went into Advanced Charging Settings and set up our home address as a location. For this location I was able to specify the max charge. When I now go back to the main charging screen the max charge is correct *and* I can now change it to anything I want. Not sure why I was required to have a location and also not sure what will happen when trying to charge at a different location!
