Rear suspension noisy?
#51
The Sportback with 20" does not produce the booming as much as the normal eTron on 21" and 20".
For whatever reason the eTron SB is better regarding the suspension boom and the whining of the motors (SB is MUCH BETTER).
And i have to add that my A6 50TDI (C8) has also the body boom. The common factor here is the air suspension. The traditional springs may act also as a buffer for the booming. Mercedes EQC with traditional springs does not have the booming.
#52
Club AutoUnion
Now that I have listened to those representative audio samples, I definitely notice that low frequency noise. It doesn't bother me, but it's definitely there. As stated above, I wonder whether it's related to the air suspension.
#53
Abstract: With battery electric vehicles (BEV), due to the absence of the combustion process, the rolling noise comes even more into play. The BEV technology also leads to different concepts of how to mount the electric engine in the car. Commonly, also applied with the Audi e-tron, the rear engine is mounted on a subframe, which again is connected to the body structure. This concept leads to a better insulation in the high frequency range, yet it bears some problems in designing the mounts for ride comfort (up to 20Hz) or body boom (up to 70Hz).
I am more convinced now than ever that all e-trons suffer from this symptom and in fact most owners do not pick up on the 'boom' or/and they simply do not find it bothersome.
#54
I listened to the audio recordings provided by Multiphonic using the sound system on my desktop. I could definitely hear the low frequency whine and even get a sense of the slight pressure in my ears. That sound I definitely do not hear in my 2019 Quattro 55.
#55
I think it's far more likely to be linked to how the rear motor is mounted to the subframe as per this article which may also explain WildBTK referred to the rear suspension.
#56
That's interesting that your e-tron is not exhibiting the same booming sound. My e-tron is a 2020 year model with production number in the 22k+ area. The other e-tron I tested which also exhibited the exact same 'boom' symptoms was a slightly later 2020 year model.
#57
Here is one article regarding the changes: https://www.audi-mediacenter.com/en/...i-e-tron-12382
#58
If you were referring to me, my eTron definitely exhibited the booming sound. I have not driven a Sportback or a 2021 eTron (they aren't in showrooms yet). My eTron was returned to the dealership on Saturday, so I no longer have an Audi, however, I still believe in the company and product and will still be active on this forum. When the time comes, I plan to investigate both a 2021 eTron SB and SUV and see if the numbers look good to be another eTron owner.
#59
However, do you know what year and production number your car was? You can determine this from the VIN. Year would be K for 2019 and L for 2020. Last 6 numbers of the VIN refer to the production number. I'm trying to determine whether this is a more recent issue so your help is much appreciated.
#60
Apologies I was referring to JNealCox's reply.
