Using the included Charger
#31
Not an expert but depending on the engineering at lower loads the EVSE may revert to a single pole and so need a neutral. In any case it is always good practice to land the neutral for a 14-50. If one of the hots has an issue there are 2 paths to ground and not just one.
#32
When I bought the car I installed a Juice Box 40, which I've used for the last week or so since I got it. I just yesterday tried the included charger for the first time, and I've found everywhere I plug it in leads to the top three lights lighting up red as pictured below.
I called Audi and they said that the charger requires and extra ground wire on the 14-50R NEMA plug. But to be frank, at the office and the supermarket, other cars can plugin (Teslas, Prius, etc).
Did Audi really give us a charger that is incompatible with most infrastructure? Is mine just broken? (Audi Dealer didnt have a compatible 240v plug to test, but they had a service bulletin where people were complaining about the problem)
No issues at 110V, but of course, thats not the issue.
Thanks,
-Ed.
Thanks,
-Ed.
Afz (07-05-2020)
#33
Can you please post link to German e-tron manual?
I have another concern - will I be able to charge my e-tron in Europe from AC source at home (not at public chargers which are usually using DC).
Anyone knows will Audi e-tron compact charging system supplied with the vehicle work at European type outlet 240V (one hot wire, one neutral and one ground).
Thanks!
Thanks!
#34
Thanks!
Thanks!
There are also several threads in that forum about using the Audi charger on European outlets.
#35
I got access to the German manual through the German e-tron forum at https://www.motor-talk.de/forum/audi-e-tron-b1055.html. I remember there were some concerns raised about copyright after the manual was posted online, so the related link(s)/thread(s) might have been deleted.
#36
Afz (07-05-2020)
#37
I had the exact same problem and it was fixed with the very recent Audi recall software update of the EVSE unit. Apparently the problem was related to 208v line compatibility, which they managed to fix with a software update. Get your EVSEs update people!
#38
Do you mean that they can update the charger itself? I have the exact same issue (Europe).
#39
Yes, they can update the charger. Here on the US, that fixed the 208V issue and it now remembers whether it is set to 50% or 100%. I am not sure if the addressed a similar 208V issue since that is a non-standard voltage level. Bit it never hurts to ask Audi about it.
#40
