Why not use Porsche's Battery Supplier?
I have read the new Motor Trend "future" vehicles feature in the latest issue. I looked for two vehicles to be on the list and they were both there:
Porsche Taycan
Audi E-tron GT
The commentary on the Audi reveal said that it was a "nicely rebodied, Taycan."
The range for the Porsche: "more than 300 miles."
The Audis' range: 204 miles.
The performance is similar for both: ~3.5 seconds to 60.
The price, assumed to be "base": $85,000 Porcshe, $75,000 Audi.
Does Audi get "last gen" batteries and Porsche "current gen?"
I've seen the ads, watched the youtube videos, read several reviews (most of them good), and I have driven the E-tron.
I had two of the spaces in my three-car garage set up for level-two charging (using 240volt, 40amp, 10kw JuiceBox charging technology): I'm ready.
I drive, however, one-way, to/from Columbus from Cincinnati. 100 miles one-way. Currently available charging stations are, currently, not conveniently located to calm "range anxiety." The "announcement" range of 248 miles was at the absolute lowest range that made sense.
I understand that "every morning" I would start fresh with 204 miles "in the tank," and 5 days a week that would, TODAY, be workable.
The Taycan, assuming the 300-mile range "sticks," gits it done.
The question, above, stands: how is it that Porsche gets a 50% longer range (is THAT what the $10,000 difference is for?) -- meanwhile, Audi gets the shortest range of the market?
The possibility of a hybrid Q8 is "somewhat" attractive but also brings with it two drivetrains both requiring at least some maintenance and, in combination, increase the complexity of the powertrain.
Luckily we have an '18 S4 and a '19 Q8, so we're not in any immediate "need to buy" situation.
This situation, described above, is both frustrating and disappointing, however -- to say nothing of confusing.
Does anyone know why the Porsche gets the "necessary range" for those of us in fly-over country who may typically need more than a 204 mile range?
Porsche Taycan
Audi E-tron GT
If I recall correctly Taycan and e-tron GT are using 800 volt charging system. It is not a whole new gen, but merely rearranging the battery cells in parallel, doubling up the charging controller to achieve double the amperage, and charging at 800 Volts vs 400-500 volts - for better efficiency and higher charging wattage with less amperage.
I think the thing you always need to think about with EVs is whatever range it's rated at is generally applicable in "ideal" conditions. So, cold temps, wind, rain, speed are going to impact that range considerably. With ICE cars, no big deal, just another 5 minute fill up. Not so with EV. Therefore, if your trip is 200 miles round trip and you want to be able to do it on one charge, you need a considerable buffer. Realistically, I'd think a 300 mile range would be optimal to minimize range anxiety in less than ideal driving conditions. Otherwise, I'd think you'd need to good a good plan B with charging at your destination or a reasonable charging site on the way home.
Hmm I think I got the above opposite. Putting the cells in (relative more) series, results in higher operating and charging voltage (800V); therefore, given the same amperage you will get double the charging rate ( compare to 400 volt) because Wattage : Voltage X current.
Up-side is more power possible ( for both charging and consuming).
One of the down-sides are there are more cells to keep balanced (via battery monitoring and management)
According to the press, Porsche Taycan 300 mile number is based on WLTP range, not EPA. So what are we looking at realistically? The WLTP range of the e-tron is 259.1 miles, which shrivelled to an EPA of 204. That same percentage decrement applied to the Taycan yields a potential EPA of just 236 miles. Fool me once…
Yes, WLTP is a fantasy. Why do they even bother? Until you start seeing real world consumption like Gerry is posting, you can't know. Even now, the data we are seeing represents pretty ideal weather conditions. Wait until winter...
I'm in a similar situation a bit further West of you. I have 85 mile each way trip that I have to do 3-4 times a month. I asked the office manger to have a 110 exterior outlet installed so I can pick up an additional 10-15 kWh each I visit just to carry a little buffer. I plan to check and test the 3 available charge locations on the route. If things look bad enough I plan to chicken out and use my ICE truck.
With the present infrastructure for EV's don't be afraid to chicken out.
Does this mean you are saying the EPA 204 for the Audi is likely to translate to 236 EPA for the Porsche? If so, that's 15% more for the Porsche -- and yet, even 236 is about 14 too low for me (your circumstances may differ) to NOT have an ICE vehicle, too.
I know the range will increase and the charging stations and accessibility will only get better -- but I'm impatient.
I did love driving the E-tron, but -- at this juncture -- my vote would have to be for a Q8 for the sole reason of "range."
The EA chargers are going in at a remarkable pace here on the West Coast, so we're lucky. One 150kW charger along your route is all you need. A 10 minute charge and you'd be set. Gotta plan for winter and bad weather as well and that would give you the flexibility.
