Problems with CCS Charging
Its a lovely car but I've found myself taking more
long journeys. I must say I find the charging network in the UK so infuriating...
my last three attempts to use CCS charging have failed. Saying it’s been unable to connect to the car. The light goes yellow and says no power supply.
Is anyone else finding problems?
A new other frustrations;
1. My range has never said more than 191 miles since leaving the dealership when it said 260. Fault?
2. My OLED wing-mirror is very dark on the drivers side. Virtually unable to see the image. It’s as if the brightness hasn’t adjusted.
Thanks in advance
Thanks in advance
I've only had my Etron since Friday but I've had an intermittent problem with the driver side display for the virtual mirror too. it occaisionally goes dark too and is then also unresponsive to touch to change mirror orientation, etc. I was going to take it to the dealer after work today but typically it started working again! Does your touch still work even with the dark display?
Otherwise i'm loving the Etron
By the way, I have been made aware through another forum that it is illegal to drive a car without a functioning driver side rear view mirror, which is what this fault amounts to.
Thanks in advance
I know this post is old but I'm having same issue with CCS chargers. You ever figure out what the issue was?
D
