Range Problems
Remember though that the range estimates are all based on best case scenarios, such as ambient temps around 78dF; no/little wind; no rain; average speed around 55mph iirc, etc.
Also, do you have the 50 or 55 etron?
I am next going to carefully monitor charging - maybe there’s phantom drain going on and I’m losing more power than what the consumption is actually showing? I assume that number should include all draws though…
any idea what this suggests?
it only used 48 miles of battery. Not sure how that works
i have a Mercedes EQC which puts about 220 miles into the battery but every mile is correct.
Next you hop in the car and do 60MPH for a good distance where the consumption is much lower; not to mention possibly some regen. Your overall consumption is much lower and since the GOM is constantly recalculating you use less kWh/mi than at the highway drive, resulting in less miles subtracted from the GOM and more range.
Keep in mind that the GOM is constantly recalculating based on the consumption. If all your trips were at the same MPH, same weather conditions then the GOM would always subtract a mile for every mile driven.
The only true measure of whether your battery is in good health, is whether your measured consumption (in mi/kWh or Wh/mi) matches to your battery capacity and utilization (as shown by the SoC% meter in the dash).
So let's say you start your morning with the car charged to 80% SoC (which means it has 80% of 106kWh == 85kWh of usable energy in the battery. You drive around all day and when you get home, the SoC% meter reports that you are at 63%. This means you depleted 17% of the 106kWh of usable energy, or 18kWh. Then you can look at the "Short Term Memory" on the virtual cockpit. Let's say it shows a short-term consumption of 2.8 mi/kWh. This means that for the 18kWh expended, you should have driven 18*2.8 = 50 miles.
In the (rare) situation where your battery is actually damaged or defective, you'll have consumption figures that all seem to line up, but the SoC% won't match. In the above example, let's say that you arrived home from that 50 mile drive and your Short Term Memory is showing a consumption rate of 2.8 mi/kWh. But instead of showing 63% SoC (17% drain), it shows 60% SoC (20% drain). 20% of 106kWh is 21 kWh, which at 2.8 mi/kWh should have taken you 60 miles, not the 50 you actually drove. So the percentage drain on the battery doesn't match the actual consumption and mileage, indicating that you aren't getting your full battery capacity (in this example, I'm assuming that 20kWh of cells are malfunctioning).
That's the only kind of evidence that your Audi dealer will accept as evidence that the battery might be defective. You must be able to show that, given a measured consumption rate, that you aren't getting the mileage out of the car that is expected. They can then use that to justify dropping the battery out of the car and testing all the cell packs to see if one is not working. In the (again, rare) case that this happens, the symptom is that the car behaves as if it has a smaller battery (and thus, the SoC% drops at a faster rate than expected given a consumption rate and mileage).
