Loaner GPS
I know that Audi will loan me a GPS to use while there. Some of the older posts seem to say that the GPS units were not very good and some people have brought their own from home. Does anyone who has used one of the loaner units in the past year or so have anything to say about them? Is it worth buying and bringing one from home that will only be used once? I think the cheapest ones pre-loaded with European maps are around $179 or so.
Originally Posted by gforaker
(Post 24602496)
(Post 24602496)
(Post 24602496)
Munich and Salzburg are not easy towns to navigate and our unit worked fine The only thing was the unit had a slight delay and you had to pay attention on what turn you needed to do or you would pass it by before it told you to turn. However, that was on the tight streets of Salzburg with limited view of the sky. I don't think I would buy one. As a failsafe Google Maps from my iPhone would have been the backup, but make sure you have an international data plan |
There's a guy over at the Bimmerfest Forum that rents out European map on a SD card for $20 or a Garmin GPS unit for $50.
$20 Garmin Map Europe NT SD Rental $50 Nav Rental - Bimmerfest - BMW Forums |
Same experience. The loaner they gave me worked great. I think was actually brand new. My only complaint is that it took a little while get a satellite signal after a full power off.
Originally Posted by Q5forWife
(Post 24602652)
$20 Garmin Map Europe NT SD Rental $50 Nav Rental - Bimmerfest - BMW Forums Great guy, highly recommend. He is in LA, CA |
Thanks, everyone. It sounds like I will be OK with the GPS they loan me.
Picked up my new SQ5 in Ingolstadt on July 23rd and dropped it off in Madrid (after driving some 3500 miles) for shipment to the USA on August 20th. In my opinion, the Garmin GPS Audi loaned us was worse than terrible. Many, many times it was absolutely worthless. Either couldn't figure out where we were or where we were trying to go or it would put us in a circle loop over and over unable to find its way out. If I hadn't had my iPhone with the Maps app we'd still be lost somewhere in Europe.
I've taken ED on BMWs the previous two years (ALPINAs) and they give you a USB unit for Europe that is unbelievably good with accuracy down to 40 feet with verbal instructions in English (or other languages if preferred). Audi should be ashamed not to do something similar. The Garmin unit was so, so bad. |
I contacted Sarah yesterday and this morning I get her response:
Thank you for the note and link. Due to the way our MMI system works we are restricted to providing a portable GPS unit. Changing the head unit for European maps, etc. is quite costly and would further delay the return of the car to the US for final delivery. This is the first I’ve heard someone having an issue with the Garmin unit. I know the signal is difficult to obtain when the car is inside the delivery center but once on the road it is fine. st Thank You, All! |
