Basic Idle Switch and Throttle Position switch testing (from the Bentley)
For the Idle Switch (or Closed Throttle Position (CTP) switch):
From pg J 24-64 Bentley Vol 1: - Disconnect Throttle position (TP) sensor connector. - Set Multimeter to resistance range - where Pin 1 of the TP sensor is at the top and pin 6 is at the bottom, connect the multimeter between pins 4 and 6 - Resistance must be 0 ohms (continuity) - Open throttle valve slightly - Resistance must be infinite ohms (open). Checking voltage supply: Disconnect the harness connector from the TP sensor - Switch ignition ON - Connect digital multimeter set to 20 VDC, in turn, between - Terminals 1 and 2 in harness connector where, with the connector wire "bail" (spring) up, terminal 1 is on the left and 6 is one the right, voltage should be between 4.5 and 5.5 VDC - Terminals 2 and 3, voltage should be between 4.5 and 5.5 VDC - If no, check ECU (ECM) and ECU wiring - If yes, check the resistance of the TP sensor Checking the TP sensor resistance (from Bentley Vol 1, pg. J24-72): Where pin 1 on the TP sensor is at the top and pin 6 is at the bottom, with the digital multimeter set to resistance, - Connect between terminals 1 and 2: - Must be 1500 to 2600 ohms - Connect between terminals 2 and 3: - Must be 750 to 1300 ohms Measure resistance again while bringing the throttle lever slowly to Wide Open Throttle (WOT) position: - Must increase to 3600 ohms maximum If NO (for one or both circuits) - replace TP sensor (PN 078 133 154 - common to many Audi's of the same vintage). Hope that helps |
