California Adventure: 1995.5 Audi UrS6 Europa Blue/Ecru 160k I picked up last weekend...
A buddy and myself flew down at 11.30am on saturday to LAX to meet the owner of the car, at the airport, made our transaction and hit the road. I had made plans to stop by 034EFI in Fremont, CA to attend their dyno day and get a good baseline and an idea of the MTM Stage 1+ Chip in the car vs. 034's Stage 1 chip which they had an ECU ready to go to compare when I got there. I then had a stop planned in Rancho Cordova, CA to pickup a drivers seat as well that evening after the dyno day. First impressions of the car were very rough, the paint looked like it hadnt seen wax in the past 5 years and the cars paint was in what I consider pretty rough shape when I picked it up.
<img src="http://i12.photobucket.com/albums/a209/blakeskate05/YE3X0608.jpg"> <img src="http://i12.photobucket.com/albums/a209/blakeskate05/YE3X0607.jpg"> <img src="http://i12.photobucket.com/albums/a209/blakeskate05/YE3X0605.jpg"> Some random shots around 034 when I got there: <img src="http://i12.photobucket.com/albums/a209/blakeskate05/YE3X0603.jpg"> <img src="http://i12.photobucket.com/albums/a209/blakeskate05/YE3X0610.jpg"> <img src="http://i12.photobucket.com/albums/a209/blakeskate05/YE3X0613.jpg"> <img src="http://i12.photobucket.com/albums/a209/blakeskate05/YE3X0617.jpg"> <img src="http://i12.photobucket.com/albums/a209/blakeskate05/YE3X0619.jpg"> <img src="http://i12.photobucket.com/albums/a209/blakeskate05/YE3X0625.jpg"> <img src="http://i12.photobucket.com/albums/a209/blakeskate05/YE3X0627.jpg"> <img src="http://i12.photobucket.com/albums/a209/blakeskate05/YE3X0631.jpg"> <img src="http://i12.photobucket.com/albums/a209/blakeskate05/YE3X0634.jpg"> <img src="http://i12.photobucket.com/albums/a209/blakeskate05/YE3X0633.jpg"> <img src="http://i12.photobucket.com/albums/a209/blakeskate05/YE3X0641.jpg"> Javad's 1100HP 5Cyl 20VT Motor on a Stand in the Showroom <img src="http://i12.photobucket.com/albums/a209/blakeskate05/YE3X0655.jpg"> <img src="http://i12.photobucket.com/albums/a209/blakeskate05/YE3X0656-1.jpg"> Finally got the S6 pulled up on the dyno: <img src="http://i12.photobucket.com/albums/a209/blakeskate05/YE3X0654.jpg"> <img src="http://i12.photobucket.com/albums/a209/blakeskate05/YE3X0652.jpg"> <img src="http://i12.photobucket.com/albums/a209/blakeskate05/YE3X0650.jpg"> <img src="http://i12.photobucket.com/albums/a209/blakeskate05/YE3X0639.jpg"> Interesting results with the 94 Octane MTM Chip running crappy 91 CA gas showed detonation and whatnot which caused us to stop dynoing with that chipset in. From Nate at 034 after the dyno: "Just a recap of what we were seeing, the chipset in your car has a pretty wide AFR range through the pull, from ~15:1 at the low end at 19lbs of boost, to the high 10's, then back up to ~11ish up top. Also, based on the power it's making it's running a bunch more timing, which is nice, when the motor's not detonating. As you can see there's less boost and more power. However, with this as you run the risk of knock as seen mid-pull with loss of power/timing pullback. Plus possible engine damage if one were to consistently stay in the power under those conditions. So, like I mentioned earlier, our chipset wasn't designed to be the most aggressive, most power possible on the stock parts. Just designed to work safely in a street driven car, and in the end is nearly as powerful it seems as a ragged edge tune." Video of Duty cycle on MTM Chip can be seen here: http://www.034motorsport.com/gallery/v/dyno_plots/Blake_injector_duty_cycle_compare.wmv.html <img src="http://i12.photobucket.com/albums/a209/blakeskate05/034stage1_MTMStage1.png"> So we successfully did the dyno pulls and left with the knowledge of how dangerous this chip might be so I kept off the throttle almost entirely and tried as best as we could to stay off the car on the rest of the drive home or atleast til I could get some 92 Octane in it and add some race fuel... Outside of Corvalis, OR we needed to pass and low and behold, the boost hose blew. I knew exactly what had happened and all I needed was a screwdriver. Ended up leaving us stranded for about 3.5 hours til my sister in law brought a screwdriver. The tool kit was missing it and I hadnt thought to buy any tools as the car was running so smoothly ;-) <img src="http://i12.photobucket.com/albums/a209/blakeskate05/YE3X0661.jpg"> <img src="http://i12.photobucket.com/albums/a209/blakeskate05/YE3X0664.jpg"> <img src="http://i12.photobucket.com/albums/a209/blakeskate05/YE3X0667.jpg"> <img src="http://i12.photobucket.com/albums/a209/blakeskate05/YE3X0669.jpg"> Then we got back on the road and just inside washington, we stopped to get gas and noticed a nemo balloon and took this in dedication to the mysteriously smaller side mirrors on most 95.5 UrS6's deemed the "Nemo Mirror" <img src="http://i12.photobucket.com/albums/a209/blakeskate05/YE3X0673.jpg"> Ended up going from Warm sunny LAX, to throughout California scattered rain showers to being greeted with snow when we got home Sunday at 1pm :-) <img src="http://i12.photobucket.com/albums/a209/blakeskate05/YE3X0674.jpg"> <img src="http://i12.photobucket.com/albums/a209/blakeskate05/YE3X0676.jpg"> <img src="http://i12.photobucket.com/albums/a209/blakeskate05/YE3X0677.jpg"> Writeup on the detail process soon to follow :-) |
Nice ride! You could have used a penny or dime to unscrew the hose.
Believe it or not, didnt have a dime, but a penny was too big :-/
I tried everything I possibly could until the screwdriver arrived from Salem. Not even the cop who stopped had anything that helped...
remove the front badge and use the steel clips, they are very, very strong
"Magruber, making screw drivers from the badge clip on the roadside, MAGRUBER!"
Awesome write-up! Sounds like a fun trip home. Would you do it again?
Always down for a trip to pick up a new car :-)
Nice writeup! Good seeing you on the way through.
Couldn't unplug the MAF and limp it off the highway to a store??
