Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
Coil testing part II
Old 02-09-2005, 10:46 PM
UrSoccer_mobileĀ®'s Avatar
Default Coil testing part II
This time around, I laid the coil pack on the valve cover and made sure all 5 plugs were touching metal for ground and I got crisp blue sparks from all 5 plugs.. hmmmm. Bad POS maybe?
The pursuit is still on.
Old 02-10-2005, 03:10 AM
Tech Guru
4Driver4's Avatar
Default Not enough. (edit - link added)
Since most bad coils tend to misfire at higher boost, your test is inconclusive. Buy a spark tester and test each plug separately, gradually widening the tester gap. See if one won't jump as far as the others.
Don't forget to unplug the injectors.
There is a more thorough write-up on Audifans.com in the S list archives.<ul><li><a href="http://www.sjmautotechnik.com/trouble_shooting/S4_Ignition.htm">This might be a little more help (SJM)</a></li></ul>
Old 02-10-2005, 05:59 AM
New Member
randerson's Avatar
Default One way to know if it's the PS or coil .....
.... is to find someone with another S4/S6 and swap out the entire top set of 5 coils. Put his on you car, drive hard a little., and if you have full boost again, then you know it's the coil and not the POS. If it still stutters at high bosst, then it's the POS.
Robert
Old 02-10-2005, 07:43 AM
Default Re: Not enough. (edit - link added)
i saw that write up but it also says to disconnect all 4 coils that are not being tested. Does that mean i have to cut the wires off on all 4 coils while testing the other? I don't feel like doing that yet. Or maybe I can buy 5 tester and do 'em all at once.
Old 02-10-2005, 08:23 AM
Tech Guru
4Driver4's Avatar
Hmmm. Honestly, I doubt I would bother, I'd just stick a spark plug in each of the four untested.
sincitys4
04-29-2011 01:06 PM
kmsnsx
04-15-2009 08:40 AM
alpinab7
07-15-2005 08:46 PM
UrSoccer_mobileĀ®
02-07-2005 12:34 PM
EB_1920
12-06-2004 08:36 AM
Quick Reply: Coil testing part II
