Erratic Idle
Erratic Idle
Hi fault codes 17887 / P1479 + 18320 / P1912 i have replaced Relay for vacuum pump also Brake pressure sensor, The pump was taken off and bench tested working.
Due to the splutter at idle like coughing back inside inlet manifold i also replace cam sensor just incase.
Car will rev up no probs and on road drives fine but wont idle from cold
Thanks Kenny
Thanks Kenny
Due to the splutter at idle like coughing back inside inlet manifold i also replace cam sensor just in case. Car will rev up no probs and on road drives fine but wont idle from cold
Thanks Kenny
Thanks Kenny
Based on the "Vacuum pump" comment and the 17887/ P1479/005241 - Brake Boost Vacuum System: Mechanical Failure code, I am not even sure that you have a C4 UrS4/UrS6.
Is the engine a 20V turbo or a V6?
Redneck Truck
11-04-2010 04:35 PM
audi/s/scott
Audi Original "S" Cars
13
10-29-2008 11:08 AM
voikoo
19
08-28-2008 04:59 PM
