Front Sway Bar Bushings
This example build tag shows the NON-sport suspension code in the lower right corner "1BA". The Sport Suspension code is "1BE".
Once you know which suspension, or you measure the diameter of the front anti-sway bar, you can then order the correct bushing. The 1BE sport suspension will have a 28 mm thick anti-sway bar. The 1BA non-sport suspension is 26 mm. The bushing PNs are 4A0 411 327 G for the 26 mm bar and 4A0 411 327 J for the 28 mm bar. Confirm this by looking at Item 21 in this useful website output:
Click Here: suspension; wishbone; wheel hub; anti-roll bar Audi 100 quattro (A10Q) 1992 year Audi USA 407010
As for doing the work, this is what you are up against, removing Item 22 "clamp", via removing nut 24 from bolt 23 on both sides (more under diagram)
Here is a better look at the front subframe, in this case, upside down, showing the Items 22 and 24 as you would see them from underneath the car.
You're going to need to get the front of the car up on jack stands with the front wheels off. (I will leave you to do that safely).
Getting at the Item 24 nut while holding the top of the Item 23 bolt is an exercise in frustration unless you drop the front of the front subframe (can be done without dropping the subframe down a bit but dropping the front subframe down a bit would help). Just be aware that in theory, the subframe bolts are single use. Item 17 here:
While I think of it here are some torque values that you will need (2 page pdf): http://12v.org/urs/FrontSuspensionTorqueValues.PDF
Once you have the Item 22 "clamp"s are off, the anti-sway bar bushing might still be still jambed up against the bottom of the subframe. This is because the suspension is hanging down. The solution will then be to use a jack on the bottom of the lower control arm where the antisway bar end goes through it and jacking up (on both sides, i.e. two jacks), just enough to pivot the antisway bar away from the subframe enough so you can slip the old bushings out (they are split) and slip the new ones in. I would consider spraying a rubber-safe silicone spray on the inside of the bushing and on the sway bar to make their lives friction free.
Once the bushings are in place, remove the jacks from the bottom of the two lower control arms and reinstall the Items 22, 23 and 24 (have fun with those bolts and nuts). Note the torque as spec'd in the pdf. If you did drop the subframe down, replace the Item 17 N90583401 bolts and torque and stretch them (the 1/4 turn after you hit the torque value = the stretch).
I think that should be it.
Cmmartin23
26
08-23-2016 04:44 PM
Audi A4 2002 S4 6spd 98k
rsixxer23
01-06-2016 03:25 AM
Nish
S6 (C7 Platform) Discussion
09-14-2015 10:02 AM
Audi Other 2013 Audi RS5 (low mileage) $61,000
buiyahkah
09-07-2015 09:29 AM
ECS Tuning-Audi
09-01-2015 12:25 PM
