Go Back  AudiWorld Forums > Audi Models > Audi Original "S" Cars
Reload this Page >
guys what tyre pressures are you running in on 225x40x18's and putting in 38psi??
Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
Old 01-29-2008, 08:25 AM
New Member
Default guys what tyre pressures are you running in on 225x40x18's and putting in 38psi??
just that im finding im getting shoulder wear on my fronts,i run mitchelin pilot 2's,and get about 15thousand miles out of the fronts.my alignment is done every year,and my shocks are new,and front bushes new.Is it just a trait of our cars to wear on the shoulders,or do you recon to put a couple of psi more in.
Damien
AUDIDOIT is offline
Old 01-29-2008, 08:27 AM
New Member
Re: guys what tyre pressures are you running on 225x40x18's im putting in 38psi??
AUDIDOIT is offline
Old 01-29-2008, 09:03 AM
Default I run 38-40psi all around on my 17s
and 42 all around when i know the car will be loaded (as in full of people and luggage for a trip), that's per audi's recommendations on the fuel door.
tpierce is offline
Old 01-29-2008, 09:30 AM
Default Are you getting wear on both edges of the tire or just the inside?
Wear on just the inside edge is a sign that your alignment is off. Lowered cars often can't get within spec for camber unless you modify the camber plates or have adjustable ones.
If you are getting even wear on both inside and outside edge it could be from under inflation. 38 psi should be plenty to prevent edge wear.
ThetaTau87 is offline
Old 01-29-2008, 12:26 PM
New Member
thanks Travis will up my psi methinks.
AUDIDOIT is offline
Old 01-29-2008, 12:40 PM
New Member
Default mainly getting even edge wear on 38psi,and yes im lowered eibach and koni
just funny been the same for the last 7 years always put it down to the characteristics of the car.Thinking of increasing the psi to 40??
Damien.
AUDIDOIT is offline
Old 01-29-2008, 01:43 PM
Default 40 psi may help, but it seems like it would be pretty harsh esp w/ 18's
I would ask around at your local tire shop for suggestions.
Are you sure the tires were never driven underinflated? 38 psi is quite high. I run my 17's at 36 psi and have never had an issue with edge wear that would indicate underinflation. 18's may be different.
Old 05-28-2019, 11:09 PM
a38p7's Avatar
225x40x18 Michelin Pilot Sport 4.
if you run on these, 38psi is the correct pressure.
a38p7 is offline
Petero1818
S6 (C7 Platform) Discussion
12
03-17-2019 02:10 AM
bilbo6209
14
09-04-2015 01:57 PM
jeffkruse
09-04-2015 11:59 AM
tvelasquez1
2.0T FSI Discussion
09-01-2015 07:35 PM
zhaoweitian
A7
09-01-2015 03:15 PM
Quick Reply: guys what tyre pressures are you running in on 225x40x18's and putting in 38psi??
