If I don't use a "no-buzz" T-fitting for my boost gauge install, how loud will the buzzing be?
I forgot to purchase one with my last ECS order. 5 frickin' dollas... :-/
Oh well. I wonder if it's going to be extremely annoying.
-Mike
-Mike
I have a vdo in my 2.7T and no buzz( it's the thin white nylon tubing used)
the rubber tubing gives the buzz.. you can find that line at pep boys (gauge section) look for tubing kit and pick up one of their T fiting with the rubber adapter for that thin tubing .. but u also have more than 10 psi so i'm not sure how that will go..
try that.<ul><li><a href="http://www.egauges.com/vdo_acce.asp?Subgroup=Nylon_Tubing&Cart=">http ://www.egauges.com/vdo_acce.asp?Subgroup=Nylon_Tubing&Cart=</a</li></ul>
ALL ABOUT THE BUZZ
When i first put my guage in i didn't use the no-buzz fitting. It sounded horible. Like feed back in the speakers when you rev a motor, but 4x worse!!!!!
I finally shelled out the $$$ for the no-buzz and peace and quite was restored to my cockpit!!
Next time i know to buy the whole thing and not cheap out on my t fittings!!
I just need to make that turbo stop whining and i'll be good!!!<ul><li><a href="http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi/?partnumber=con%20003&html=learnmore.html">sto p the buzz</a></li></ul>
PIC OF MY GUAGE INSTALL
<center><img src="http://pictureposter.audiworld.com/67766/interior.jpg"></center><p>As you can see i have replaced all my stock guages with autometer phantom guages.
Boost, egt, fuel press.
With oil press and temp relocated to the bottom.
NO BUZZ FITTING = NO PROBLEMS!!!!
Re: PIC OF MY GUAGE INSTALL
Hey I've always wanted to put a boost gauge where my clock is located inside my dash----was it very hard to get in there or what??? I would like some others but all I really want is boost. If you have a good source for info on the dash removal and fitting a boost in that spot please let me know. Oh and the gauges look NICE!!!
Thanks
D
Thanks
D
I don't agree. no-buzz connector or oil dampened guage.
I had a VDO in my wife's TDI installed with the nylon tubing. Buzzed like a SOB. Get the no-buzz t-connector or an oil dampened gauge.
Hibiscus Red S4
03-03-2007 09:31 AM
Oettinger_A4
05-15-2005 02:00 PM
[Arawan]
04-17-2004 11:37 AM
Skribbs2000
01-15-2004 06:51 PM
